Nissan rims on a Subaru?
Old May 3, 2005 | 06:33 AM
tju62's Avatar
Question Nissan rims on a Subaru?
Need some help. Someone wants to buy my 18" Volks TE37's from my G, and put them on his WRX. Does anyone out there know if the bolt patterns the
same? Thanks in advance.
Old May 3, 2005 | 07:17 AM
skeleton_cru's Avatar
Sedan
Only the '05 STi's have the same bolt pattern, but I doubt the offsets will work. Maybe with spacers. Your buddy should know what offsets work for his car.
BTW, I found the answer in about two minutes using Google.
Old May 3, 2005 | 02:16 PM
kenchan's Avatar
I was using 17x7 100x5 lugs with +50mm offset SSR Comps on my WRX.
+48 to +52 is what's recommended as far as offset go on the rex.
Forgot wat the center bore diameter was.
Old May 3, 2005 | 04:25 PM
tju62's Avatar
Rims
Skeleton, Kenchan...thanks.
Old May 3, 2005 | 05:35 PM
Rookie84's Avatar
Not gonna work, period. The offsets are too low for WRX's assuming that you have right offsets for your G, be it sedan or coupe. Plus the rims would be too wide if you have 9.5 or bigger for your rear wheels.
infinitiway
Aug 8, 2017 12:38 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
5150DS
Sep 26, 2015 07:47 PM
