Track rims and tires...
Old May 8, 2005 | 06:03 PM
roneski's Avatar
Devil's Advocate
Thinking of ordering this setup tomorrow for my coupe.
5Zigen Fn01r-c 17x9 +35 (17.5 pounds each)
Toyo Proxes RA1 255/40R17 (front) 275/40R17 (rear)
My main concern is the 255s not fitting on the front. Anyone else gone with 255s in the front? Anyone see any other glaring problems with this setup?
I know that the trend has been to go same size all the way around, but I think that I can correct for the understeer with suspension, sways and tire pressure.
Old May 9, 2005 | 03:16 PM
roneski's Avatar
Devil's Advocate
255s on the front... anyone?
Old May 9, 2005 | 03:22 PM
TINMAN's Avatar
Ty,i've seen a few 255s but not on 17
Old May 9, 2005 | 04:49 PM
P_Diddy's Avatar
Are you going to do autocross or track days w/ those tires? I was also thinking about getting wheels/tires for autocross.
I saw on tirerack that Kosei K1 TS were 15.5 lbs each, 17 x 8 though.
Old May 9, 2005 | 05:27 PM
roneski's Avatar
Devil's Advocate
Yeah, gonna get those and move from B stock to BSP. They are also going to double as my drag setup even though they aren't exactly meant for it. I went with the 17x9 because I really wanted 275s on the rear.
Old May 10, 2005 | 12:25 AM
CrazyMike's Avatar
255's will fit just fine. I have 245's on my 17x8 rims. They match almost perfectly. I run STX so I'm limited to those sizes. I would really be interested to see if 275's would fit up front. One would probably have to go to a smaller offset like +25 or so. I figure with +35 offset you'd have less than 1/4" clearance with 275s, but that is just a guestimate from looking at the clearance on my car.
suby01
Not G35 Related
May 25, 2016 03:07 PM
AJC128
Nov 1, 2015 11:55 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
