Offsets???
Offsets???
I was wondering if this offset will fit a non brembo equiped g35 coupe? I dont know much about offsets, so if someone can help me out that would be great... Here are the specs: 19X8.5 +25 and 19X9.5 +29
Thanks
Thanks
Originally Posted by GXCLUSIV
That rear offset will fit non-brembo only. Your 3rd set of DPE's?
how can you say that? My rear is +41mm and it's running brembo's.
plus, i have more than 20mm clearance from the rear caliper.
Thanks
Thanks
should fit just fine.
I assumed he was inquiring about DPE's, as I stated his 3rd set. I dont believe in most cases you'll find custom built wheels for a BBK will have above +29et. Obviously alot depends on wheel brand like your SSR's with +41et for rear, definately will not work for DPE or Volks.
seagrasser
May 3, 2022 09:43 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
