Are two different tires OK?
Old May 11, 2005 | 10:35 PM
realgone's Avatar
Widdle ya into kindling
Is it OK to go with different tires front to rear.
Something like this...........
Goodyear Eagle F1 GSD3 255 35 19 front
Goodyear F1 Supercar EMT 285 35 19 rear
I want to get 285 for my 19 x 10.5 +29 volk wheels because I don't know much about stretching, but that leaves me with few choices.
The Eagle F1 does come in a 275, but like I said I don't know much about stretching, all I know is that it will fit.
Old May 12, 2005 | 12:36 AM
avs007's Avatar
I don't know anything about those specific tires, but at least make sure that the tires are of the same type. So, for example, don't be mixing MaxPerformance tires with High Performance tires, etc, etc.
Old May 12, 2005 | 09:05 AM
TINMAN's Avatar
i considered the samething a while back but after talk with tech guy at tire rack,i changed my mind and go with BFgoodrich G-Force KWD2 :245/35/19-285/35/19.
2 different tires are NOT performs the same,not wear the same and not rated the same.also those are runflat tires.the walls are very stiff.result rough ride and more road noise.go with BF
Old May 13, 2005 | 02:51 AM
ryoken's Avatar
It would affect the handling of the car. If the front tires are stickier, you'll be prone to fishtailing. If the rear tires are stickier, you'll tend to understeer more than normal.
I wouldn't recommend it, unless you only ever drive it like a passenger car, nothing spirited or aggressive.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
