Repainted Curbed Wheel
Old May 13, 2005 | 09:02 PM
HugoBoss's Avatar
Ok so I repaired my curbed my stock 18" wheel and I found a thread on how to repair using bondo etc etc.. Here is a pic of the repainted wheel and a pic of the Stock color for comparison. As you can see the repainted one is slightly lighter, perhaps this was the result of using gray primer instead of black.. Then again, what do I know?
Attached Thumbnails Repainted Curbed Wheel-clipboard01.jpg   Repainted Curbed Wheel-clipboard02.jpg
Old May 13, 2005 | 09:16 PM
calejohnson's Avatar
Nice job. Did you find the thread for the repair here?
BTW, you'll never notice the color difference with a little brake dust mixed in!
Old May 13, 2005 | 11:47 PM
HugoBoss's Avatar
Well, I found a link to a site that explains how to repair on this site. here is the link incase you need it. http://www.audiworld.com/tech/ext43.shtml
Also, I think i may keep experimenting with different colors to see if I can get a closer match. Let me know if you have any other questions about the repair..
Old May 14, 2005 | 01:28 AM
kenchan's Avatar
Just put the lighter color on the front and the brakedust will even it out in no time.
Old May 14, 2005 | 02:11 AM
Wicked_limitz's Avatar
man i wanna try this so bad on my curbed wheels but im so nervous about it. good job on yours!
Old May 14, 2005 | 02:25 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
What kind of paint did you use? Part of the difficulty with our stock 18"s is that there is no good match for the color.
Old May 14, 2005 | 06:48 AM
HugoBoss's Avatar
Oh, and I just wanted to mention that WRAH helped me out big time.. I cannot take credit for it all, without his help my rims would have looked like crap. I used Plasti-Kote
1001 BRIGHT SILVER METALLIC. I think i will go back to the shop and look for something darker and experiment. I'll keep you guys posted.
Old May 14, 2005 | 02:29 PM
E_K's Avatar
E_K
Alright, thanks for the info. Is that paint dedicated wheel paint? I painted a set of rims recently using Dupli-colors' silver wheel paint, and it turned out pretty well. It's supposed to resist heat/brake dust better than regular paint, but we'll see.
Old May 14, 2005 | 05:25 PM
HugoBoss's Avatar
Actually, Im not sure if this paint if heat/brake resistant but if thats not the case then, i'll just repaint. The paint is labeled "Body Shop Paint"
Old May 15, 2005 | 12:12 AM
WRAH's Avatar
WRAH
I've never heard of the wheel itself getting hot??? Are you thinking of the caliper?
Old May 15, 2005 | 02:45 AM
E_K's Avatar
E_K
If you heat up the brakes enough, the heat will be transferred to the wheel. But obviously it still won't reach the temps associated with the brakes.
Anyway, this is what it says on dupli-color's site on the wheel paint (not advertising for them, I really could care less if anyone buys their stuff, but it seems to work for me):
Enhance your wheel’s appearance with Dupli-Color® High Performance Wheel Coating. This advanced, track-tested, acrylic enamel formula restores original wheel appearance and protects wheels.
* Rugged acrylic enamel formula
* Fast dry
* Improved resistance to brake dust, chemicals, cleaning solvents, heat and chipping
* Highly-reflective metallic finish
* Ideal for use on steel wheels, aluminum wheels, and plastic wheel coverings
Old May 15, 2005 | 02:58 AM
E_K's Avatar
E_K
Here's a small pic of the rims that I painted. I did a few light coats of silver and a few coats of clear. It's slightly darker than stock, with more metallic flakes. Nothing major, since I didn't want to mess with these guys too much.
I would also wet sand after all the painting is done, to get a super smooth finish. I used 2000 grit sandpaper, followed by paste-type polish.
Hugoboss, if you can find a good match for the stock 18" rim color, let us know.
Old May 15, 2005 | 01:31 PM
//m-zilla's Avatar
What was awesome is that when I bought my coupe I purchased a $150 tire and wheel replacement warrenty if one was to get curbed. The warranty has no deductible and I also have it on my BMW too. I also checked into making sure it covers aftermarket wheels as well and it does. I just have to have receipts for them.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
rsingerG35
Aug 18, 2015 10:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
