Which one would you get?
Old May 17, 2005 | 09:20 PM
mark5's Avatar
I have a white sedan, no aero kit and I don't have the money for volks, besides the nyc roads would prob eat them up.
Attached Thumbnails Which one would you get?-five-s-15.jpg   Which one would you get?-mbmrev.m.ang.jpg
Old May 17, 2005 | 09:27 PM
GXCLUSIV's Avatar
You should ask if anyone will volunteer to do a photochop on a white Sedan.
Old May 18, 2005 | 12:00 AM
ssk0771's Avatar
ZZ Boy
I would get neither but if I had to choose, I would pick the first one.
Old May 18, 2005 | 08:00 AM
skeleton_cru's Avatar
Sedan
I like the first wheel better.
Old May 18, 2005 | 09:19 AM
mark5's Avatar
Ok if you don’t like any of them, what would you recommend? I want a simple clean looking 5 star rim
Old May 18, 2005 | 11:46 AM
tkman00's Avatar
i would go w/ any 5 spoke from rh/racinghart
Old May 18, 2005 | 12:04 PM
Sedan
For the budget minded:
Axis Hiro and Axis Milano
Attached Thumbnails Which one would you get?-axis-hiro.jpg   Which one would you get?-axis-milano.jpg
Old May 18, 2005 | 12:23 PM
mark5's Avatar
but I can't get 19" I live in NY. Those would have been my 1st choice
Old May 18, 2005 | 12:44 PM
kenchan's Avatar
Out of those choices, I would go with the one on the left.
The MB motoring one is a pos...it's not even clear-coated if I remember correctly.
for low priced wheels, I'd consider TSW's or those Axis wheels posted above.
Old May 18, 2005 | 02:06 PM
coupin827's Avatar
Why can't you get 19's in NY. I have 19's as do a ton of other people. You're fine w/ 19's its 20's you have to worry about.
Old May 18, 2005 | 02:22 PM
IS300TOG35's Avatar
► Matt ◄
Eh, ill throw in my .02... My first time around on my IS300 I got a set of 19 Axis Muse. Within about 6 months I warped 2 and cracked a spoke on the 3rd. I avoided everthing and also payed close attention to PSI which I kept at 35psi cold.
If you want 19's I suggest you save some more and buy a forged wheel, becuase they will hold up a lot better on the streets of NY (boston in my case), vs a cast wheel (and yes, Axis is cast.. also the ones you were choosing between are cast also)
If you budget it tight, do go for a 19 inch cast wheel (Axis), instead but some 18' casts instead and get some meatier tires.
My second time around with my IS300 I ended up going with 18' SSR GT1's with meatier tires and had no problems. Good luck on your decision
Old May 18, 2005 | 02:23 PM
GXCLUSIV's Avatar
Not just the size of wheels, but brand and quality of the wheel. Cheaper brand cast alloy wheels are easier to bend or get damage, then forged aluminum wheels ( stronger and lighter ), which are more expensive ( volks, dpe, iforged, etc. ). Save up or buy a used set of good quality wheels 19's or 20's.
Old May 18, 2005 | 02:25 PM
BlackGSedaN1027's Avatar
Me like
Old May 18, 2005 | 02:50 PM
mark5's Avatar
damn now i don't know what to do! sucks that I have to pay off so many credit cards
Old May 18, 2005 | 02:55 PM
blazinZ's Avatar
get that ones that you really like.
