Offset for sedan
Old May 26, 2005 | 02:14 PM
Renesis's Avatar
Offset for sedan
Can anyone confirm if this +35 offset will stick out on the sedan??
I am considering wheels that are 18 or 19, width 8.5 with +35 offset.
Will these stick out??
I know +38 will fit and I got the chart but many wheel stores confirmed it will not stick out?!
Old May 26, 2005 | 02:49 PM
kenchan's Avatar
From what I read, if you lower the car +35mm will look very tight..but
i would probably use +45mm if it was my car.
Old May 26, 2005 | 04:30 PM
Boon's Avatar
+38 is optimum for 8"-8.5" for front and +42/+45 for 9"-9.5" rear. if going with same size all around stick close to 8.5" with a +38. Good Luck.
Old May 26, 2005 | 04:53 PM
Texasscout's Avatar
Question
What is the widest wheel/tire you can get under the fenders of a 05 sedan dropped 1" all round. What offset would you need?
Old May 26, 2005 | 05:09 PM
khsonic03's Avatar
I was able to fit 19x8" with a 32 in the front. No problems whatsoever.
Old May 26, 2005 | 05:49 PM
Renesis's Avatar
do u have pics of ur ride khsonic03??
I want to see your wheels
oh..............
How did the tokicos fit your wheels??
I am planning to get Tokicos with Z springs on 18s or 19s but dunno if it would rub.
Old May 26, 2005 | 06:20 PM
dklau33's Avatar
I went with a 17x8 all around on a +43 offset. It looks fine but wish I would have went with a +38 offset since the front has minimal clearance with the upper control arm and my 245/245 tires. Since you are looking at 8.5" wide wheel I would suggest a +38 or a +35.
Old May 26, 2005 | 09:45 PM
Chico's Avatar
You will be fine with a 8.5" rim and +35 offset. I speak from experience. You will have a nice flush look.
I had 20x8.5 +35, 245/35/20 all the way around and it looks amazing. I didn't have any rubbing at all after I lowered it with Eibach Pro Kit.
Here is a couple of pics.
Attached Thumbnails Offset for sedan-img_0257.jpg   Offset for sedan-img_0263.jpg   Offset for sedan-img_0280.jpg
Old May 27, 2005 | 05:59 AM
skeleton_cru's Avatar
Sedan
I would not go with a +45mm with 8.5" wide wheels.
Old May 27, 2005 | 06:02 AM
Sedan
Widest on a sedan is 9.5"/+45 in the rear, 8.5"/+38 in the front.
Old May 27, 2005 | 07:40 AM
Renesis's Avatar
Since many wheels come only with +35 for 8.5, I think I would need to go for 8".
I was thinking about Axis milanos because they looked pretty good on teh sedan but then it weighs 27lbs.!!!!
So I think I am getting Enkei RP03 in 18s with 8" and +40 offset. I am most likely going to lower it and I don't wanna take risks of rubbibg issues. Is this the right way?
Old May 27, 2005 | 09:24 AM
Sedan
There are some people that are running 8.5 with the +35 and they say there is no rubbing.
What are you other offset options for the 8" wide wheel? You'll want an offset smaller then +40 if possible. Somewhere between +32 and +35, +38 at the most.
Old May 27, 2005 | 04:13 PM
Renesis's Avatar
Well, According to the chart the THX made, if its an 8' wheel, +40 is OK, in fact Gsedan35 got the same size and offsets for his RPM2 and it is a bit too tugged in . Thats why I want something more aggressive but I want to keep the width between 8" - 9" for using 245s all around. Most 9" don't come in a offset that fits the sedan so its either 8 or 8.5s.
And most 8.5s comes with +35 offset or less so that doesn't work. I guess I will have to get the 18x8 +40 then.
Old May 27, 2005 | 04:32 PM
khsonic03's Avatar
I had some pics posted, but I am not sure where they are now. I will see if I can muster some up.
Old May 27, 2005 | 06:39 PM
Sedan
I know that the +40 will fit I just didn't think you would like the "tucked in" look.
If it's between 8.5/+35 and 8/+40, I would go with the first choice. You'll be very close to the fender lip, but it will look really nice.
