? about offset
Old Jun 2, 2005 | 04:57 PM
silvsurf's Avatar
? about offset
I'm looking to purchase LE37T's 19" 8.5/9.5. I plan on going +22 in the front and possibly +12 in the back. Would the +12 look good in the back? I'm guessing the spokes would be more pointed in than the fronts with a little more lip. Am I right?
Old Jun 2, 2005 | 06:06 PM
biscotti's Avatar
+12 in the back will likely rub and you will have to roll the fender.
Old Jun 2, 2005 | 06:11 PM
Cuda's Avatar
+12 is kinda low... but if you manage to pull it off it should look solid...
Old Jun 2, 2005 | 06:34 PM
silvsurf's Avatar
damn. Sounds a bit risky. What about +34 for the rears? What kind of look would I get? Thanks for your input.
Old Jun 3, 2005 | 12:42 AM
biscotti's Avatar
+34 would be a bit more tucked in than stock and may not clear Brembos. Your ideal offsets should be low 20s to 30.
Old Jun 3, 2005 | 07:36 PM
silvsurf's Avatar
I have non-brembos. Maybe I should just stick with +22 all around?
Old Jun 4, 2005 | 12:13 AM
firefox's Avatar
I have 18x9.5 +15 offset in the back which is already really agressive. With a 275/40-18 tire, I had to dremel my fender. I happened to pick a tire that had a section width that was about 0.2" wider than normal, which made it rub right into the fender.
With a +12 offset I believe you're going to have to roll the fenders for sure. Additionally, it will look like the wheel is stuck out too much.
I think +22 all around should be okay. You may want to go with a tad higher offset on the front, if possible. Maybe +25 or +30 so that it doesn't look like the front is sticking out farther than the back.
Old Jun 4, 2005 | 01:58 AM
biscotti's Avatar
+22 on all corners will be fine.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
