staggered 20's on 04 sedan??
Old Jun 8, 2005 | 02:12 AM
bondkx01's Avatar
did a search but didn't find what I was looking for.
Have an 04 sedan with factory ground effects blah blah blah....will 20x10 in the back with Nitto 555 275 30 ZR20 fit under the wheel well? I am looking at Iforged 20 inch Aero rims.
How about
20x8.5 in the front Nitto 555 245 35 ZR20?
Have no drop so factory springs. would like to drop an inch at least all around.
What offset should I be looking for? Should I expect rubbing?
Thanks any help.
Ken
Old Jun 8, 2005 | 11:26 AM
hksjza70's Avatar
I'm running 20x9.5 + 44 rear and it barely clears the fender with a 255 falken tire, I wouldn't suggest a nitto with this offset, the sidewall is too square and may rub.
I've also got 20x8.5 +45 front (with a 7mm spacer to clear brakes) - effectively +38 - again with a falken tire.
Pretty much positive a 10" wheel will rub in the back unless there is room to get a huge offset, but then what's the use if you're still running the same sized tire?
I'm lowered so the fender is at the top of the tire.
Old Jun 8, 2005 | 12:06 PM
DXC's Avatar
DXC
AGREE. I will use Pirelli or Falken on x9.5 Don't risk!!! x9.5 & x10 is ONLY and ONLY 0.5" difference - cannot even tell by human eyes instantly
Jusseth
Sep 13, 2020 12:25 PM
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Slammed_g35
Aug 28, 2015 07:08 AM
