Is there any way to lower my car 2" without destroying my tires???
Old Jun 11, 2005 | 01:29 PM
crai6m4ck's Avatar
I have the stock 18" wheels now but I plan to get either 19's or hopefully 20's. I want to lower my car about 2" and I know that you have to get the camber and toe kits to help with the adjustments but I wanted to see if anyone has gotten 2" of drop without killing the tires?
Old Jun 11, 2005 | 10:13 PM
kenchan's Avatar
even if it doesn't kill the tires, your car's going to run like crap on the streets without
getting the camber and toe corrected.
Old Jun 12, 2005 | 01:58 AM
ZeroGen's Avatar
Omega Enthusiast
There's no way around it. You'd have to get camber correction for that much lowering.
Old Jun 12, 2005 | 04:14 AM
crai6m4ck's Avatar
No... I plan on getting the camber and toe corrected but I have heard that adjusting them only allows you to drop it an inch or so and still be within specs, after that there is nothing you can do. I want 2" and still be either within specs or very close to them. Has anyone done this?
Old Jun 12, 2005 | 09:04 AM
waijai's Avatar
i.love.gold
Sorry it's not possible. 2" is too low to get back within factory specs.
Old Jun 12, 2005 | 11:37 AM
crai6m4ck's Avatar
So what do you think is the lowest I can go and still stay within the specs?
Old Jun 12, 2005 | 03:10 PM
kenchan's Avatar
-1"
The problem is not just the camber that can be corrected using aftermarket pieces...
It is the positive caster you should be worried about which is non-adjustable and will
make your car drive like crap over bumps as it makes your car point all sorts of
directions. The best remedy is to stiffen up the struts up front so that it would not
compress much more... while balancing the vehicle dynamics with the rear using
swaybars and different camber/toe settings, damper settings, etc. so it does not
understeer like a FF on wet pavement.
Old Jun 12, 2005 | 03:21 PM
kenchan's Avatar
not sure when I posted my first post, but it looks like I was probably in Detroit during my biz trip and was getting pretty tired... and started to not make much sense.
Shouldve read:
'even if it doesn't kill the tires, your car's going to run like crap on the streets even with the camber and toe corrected.'
The issue is caster and sus travel (stroke).
1) caster's not adjustable and your car will pull over bumps.
2) stroke is too short that you'll have to use high spring and damp rate...
or end up riding on your bumpstops. either case, say bye to comfort.
Old Jun 12, 2005 | 03:23 PM
DaveG35Cee's Avatar
Tein S-tech my friend
Old Jun 12, 2005 | 03:37 PM
kenchan's Avatar
For the front, yes...but the rear needs help.
Old Jun 12, 2005 | 11:22 PM
1star2's Avatar
I was thinking of going with Tien S-techs also but was thinking of cutting the rear springs to lower it a little more. I have noticed that most people here are not happy with the rear drop on Tien S-techs. Has anyone here tried this or is it even possible?
Old Jun 12, 2005 | 11:30 PM
kenchan's Avatar
it's not just the height that's the problem. It's the spring rate. it's much too soft.
rezendvous420
May 31, 2020 01:26 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
itschuckster
Jul 25, 2015 08:07 AM
Kal Hamm
Jul 24, 2015 08:55 AM
