Lowering the coupe with Teins
Jun 15, 2005 | 06:53 PM
Quote: thanks for the reply. I am just curious to what others are doing since my rear is sitting a lot higher than I expected ~2.5 finger gaps, while the front settled to about 1-1.5 finger gap.
the rake is normal. that's how the car should sit with the S-techs
and most lowering springs.
Im using Prokit on the rear and the drop appears to be even with
the front although the car is still slightly tilted forward as it should.
You can just throw in a sound system and that'll take care of that.
Reply 0
Jun 15, 2005 | 06:54 PM
Quote: maybe i should just save my money
if you're only planning to do just springs, yep, save your money.
Reply 0
Jun 15, 2005 | 08:41 PM
why doing just springs is a waste?
Reply 0
Jun 15, 2005 | 09:32 PM
Quote: why doing just springs is a waste?
most likely you'll need camber arms front or back, both perhaps. Just don't be suprised if you have to buy them. Be prepared to shell some money out for them. Eventually you'll have to upgrade your shocks, lowering springs tend to wear out OEM shocks quicker.
Reply 0
Jun 15, 2005 | 09:57 PM
Quote: the rake is normal. that's how the car should sit with the S-techs
I had a friend that weighs 170lb sit in the trunk.. it gave me the height i was looking for So a system wont be enough lol.
But surprisingly, my camber doesn't look so bad, but I haven't gotten an alignment yet.
Reply 0
Jun 15, 2005 | 10:47 PM
hahaha. lol
Reply 0
Jun 16, 2005 | 07:59 AM
Fwiw...
My local Nissan dealer also does performance mods and is an authorized Stillen dealer and installer. He has told me that Tein H Techs for the G35 (.6f/.3r drop) will definitely not need a camber kit to put the car back in spec.
He said that the cars come with about 2 degrees of play that will more than compensate for the difference in the spring height.
Now the question is whether that small a drop will make a noticeable difference. Personally, right now I'm on the fence about getting them. Also pricewise, I was quoted approx $200 for the springs and $400 for installation (8 hours @ $50/hr).
Reply 0
Jun 16, 2005 | 10:59 AM
400 for just install????WTF! Dude, don't even go with that guy. Go find someone with tools and they can install it for way cheaper than that! It only takes 1 hour!
Reply 0
Jun 16, 2005 | 12:20 PM
Quote: 400 for just install????WTF! Dude, don't even go with that guy. Go find someone with tools and they can install it for way cheaper than that! It only takes 1 hour!
One hour? Are you sure? That's 15 mins per wheel. I mean, don't get me wrong, I think 8 hrs is a bit much, but 1 hours seems really fast.
But my ignorance is showing, I don't know much about what this job takes. Anyone else care to chime in with the time they know it takes to replace 4 springs on a G35c?
Reply 0
Jun 17, 2005 | 12:53 AM
I took me 15mins per side on the rear, about 45min each side on the front using handtools. it's about a 2-2.5hr job.
Reply 0
Jun 20, 2005 | 10:50 AM
s tech in my s14 isnt all that great they dont last long at all.. i had them before they were kinda stiff when i first installed it then it just got all soft, i heard the htechs are alot better..
Reply 0
