18" wheels for sedan
Old Jun 12, 2003 | 12:09 AM
humg35's Avatar
Hello,
I was wondering if anyone with the sedan has changed their wheels with the following configuration:
front 18 X 7.5 225/45/18 Wheels with 1.10%
rear 18 X 9.0 255/40/18 Wheels with 1.30%
front 18 X 7.5 225/40/19 Wheels with 0.90%
rear 18 X 9.0 255/35/19 Wheels with 1.10%
1) Will there be enough clearance for the rear fender with the 255 tires ?
2) If I drop the suspension with Eibach springs, will the 255 tires still fit the rear.
3) Will the car's VDC be affected with the small difference in diameter from the stock wheel ?
4) How does the ride feel compared to the original setup when the profiles are lowered to 40 and 45 series ?
5) Will the car's fuel economy drop significantly ?
Old Jun 12, 2003 | 09:24 AM
chinee's Avatar
Re: 18" wheels for sedan
I'm also looking at 18's but would probably go with the coupe specs. Or if I want to keep tire rotation possible, 235/45 or 245/45 all around.
03 G35
02 Sequoia
Old Jun 12, 2003 | 11:27 AM
g35doman's Avatar
hmm, would this mean that notwithstanding the VDC/staggered tire issue, 225/50/17 all around would be better than 235/50/17 (even though the 235s are closer to stock dia.)?
In other words, is it a better fit clearance wise and close enough speedometer wise?
g35doman
'03.5 5AS, BS/G, Leather, Sport, 32%, Klasse
Old Jun 12, 2003 | 01:09 PM
chinee's Avatar
You know what? I've never really understood that VDC/staggered issue... partly because it seems to me that the VDC would work on the powered (rear) wheels (I night be wrong), so if the front's a different size, it should not matter. Guess I gotta do a little research... but at a minimum, same size all around should not affect the VDC at all (I think).
03 G35
02 Sequoia
Old Jun 12, 2003 | 05:43 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
I know someone with 19" On their Sedan
Front 19x8.5 245-35-19
Rear 19x10 265-30-19
Old Jun 18, 2003 | 01:58 AM
ryoken's Avatar
That's because, officially, Infiniti says that 225 is the max recommended width for the front wheel well on the coupe or sedan.
chinee: I agree on the VDC issue. It's what I've heard, and I'm not willing to take the risk (plus my original tires are far from needing replacement). Just waiting for someone to say "Hey, I put 15" tires on the front and 24" tires on the back, and the slip light never comes on!" Err... you get the idea. [img]/w3timages/icons/smile.gif[/img]
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
teamghost
Jul 28, 2015 04:52 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
