feel stupid asking this, but....
Old Nov 29, 2002 | 05:09 AM
lilteyang's Avatar
... when you up-grade your wheels, you'd have to up-grade your tires accordingly, meaning the thickness of the side-wall has to be taken into consideration, correct????
... If so, then what thickness is recommanded for the tires with 18'' rims in order to preserve the over-all diameter of the stock wheels??? I was told this is important because they effect the odometer, the speedometer, and also the traction control......
Old Nov 29, 2002 | 02:48 PM
lilteyang's Avatar
Re: feel stupid asking this, but....
yeah.... found a site that taught me how to do the cauculations.... and spent 2 hours trying to find 235/45-18s...
the only one I found was a Pirelli... which is pretty good... but only Z rated.... (i know I'm never gonna go over 139 mph, but it's good knowing that I CAN)...
well, is 1% really important...??? or can we just re-configure the speedometer and odometer???
Old Dec 2, 2002 | 06:46 PM
hoshtaylor's Avatar
it's almost nothing...you can use this to calculate it...
http://www.volkswagen.org/tiresize.htm
or this
http://www.therangerstation.com/Spee...rom_Tires.html
you can do a search and find whichever "chart" works best for you.
Old Dec 19, 2002 | 11:25 PM
Spyder500's Avatar
Buy the Bridgestone S03's if your a straight baller, newest tire technology in the market and is rated the best tire you can buy for money.
I recommend:
Bridgestone Potenza S-03 Pole Position
Front: 225/35-18 YR $170 Max Performance
Rear: 255/35-18 YR $210 Max Performance.
Yes I know its Not stock standard tire size as you can see. But for increased performance I'm buying them when I wear out. Buy +1 wider, +1 lower profile. Increases handling greatly! The most critical thing about suspension is the tires because thats what it rides on. Doesn't matter that much when you have $3000 suspension but using crappy tires. You could out perform that $3000 suspension with $1000 performance tires. But in the thinner profile you sacerfice ride quality and would feel a lot more bumps and etc. Its worth it for me, is it worth it for you? Smoke that E46 M3 in that turn. maybe =)
Show them whats up with the G on your S03's.
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
aaron3719
Sep 29, 2015 10:12 AM
