Wheel weights for OEM wheels
Old Jun 19, 2005 | 06:56 PM
Frostydc4's Avatar
How much do the 17", 18", and 19" OEM forged wheels weigh? Thanks!
Old Jun 19, 2005 | 07:17 PM
GLuXuRy's Avatar
LOTS LoL i dunno, all i know is my 18s are heavier than sh*t
Old Jun 19, 2005 | 08:34 PM
cyphr's Avatar
oem g35 19s are 19lbs in the front and 20lbs in the rear. I have no idea about the other wheels though, sorry.
Old Jun 19, 2005 | 10:08 PM
g35doc's Avatar
OEM 18s are about 25 lbs.
Old Jun 19, 2005 | 11:26 PM
1nate7's Avatar
Originally Posted by g35doc
OEM 18s are about 18 lbs.
If you're talking about the coupe OEM 18's then they are a lot heavier than that, closer to 25 lbs.
Old Jun 20, 2005 | 12:25 AM
g6g35's Avatar
no way...
Old Jun 20, 2005 | 12:34 AM
Vic's Avatar
Vic
so the OEM 18" is heavier than the OEM 19"?
Old Jun 20, 2005 | 02:36 AM
Sukairain's Avatar
18 = cast (appx 24.5lbs)
19 = Rays Engineering forged (appx 19.5-20.5lbs)
Old Jun 20, 2005 | 12:46 PM
dklau33's Avatar
The 17" 5 spoke sport sedan wheels from my 2004 sedan weigh about 23 lbs.
Old Jun 20, 2005 | 01:02 PM
g35sedamn's Avatar
i have 350z track wheels (forged by rays engineering) i believe they are 18.1 in the front and 18.8 lbs in the rear.
Old Jun 20, 2005 | 07:33 PM
g35doc's Avatar
My bad. I typed in the wrong number.
Old Jun 20, 2005 | 09:04 PM
Frostydc4's Avatar
Damn! I never knew the 18" wheels weighed that much . Are they made by enkei? Another question. How much do the 19 rays forged wheels cost? If they cost a lot of $$$ then I will go for a set of 18" CE28N's and lose some weight!
Old Jun 20, 2005 | 10:30 PM
wanalaugh74's Avatar
Really?? how in da HE** did you get these on? I tried a friend's Z rims (dont think they were trak but they are 18's.. i only know b/c he gave me his tires..) but they werent even close to fittin on my sedan. The bolts and nuts were too short to hold them on. GOt pics?? Any help would be great.. Thx in adv.
Old Jun 21, 2005 | 01:39 AM
Sukairain's Avatar
Stock 19" are the Best 'Bang 4 da Buck' performance/style rims you can find for our cars. They are Rays Engineering forged monoblock 19" wheels comparable to the TE37 or CE28N in both construction and weight. The only downside is the lack of big lips and width compared to aftermarket. However, performance wise it might actually be beneficial to keep the stock width front and rear to both save weight and prevent more understeer. I am still not sure why Nissan/Infiniti chose not to advertise the stock 19 rims as Rays Engineering rims, you can clearly see the RAYS logo on the inner hubs of these wheels.
Stock 19s seem to be going for anywhere between $1500-$2000 on Ebay new with tires. This is a very good deal consider a similar setup Volk wheels with tires will cost easily over $3000. Base on my conversation with Bridgestone techs and Infiniti techs at JGTC, the Bridgestone Potenza RE050A (stock 19 tires) are superior to both Michelin Pilot Sport (stock 18) and their S-03 tires. Many new superars including Ferrari, Maserati and Porsche use RE050A tires.
Hope that helps.
Old Jun 21, 2005 | 05:13 PM
G35fromPA's Avatar
Keep in mind that raw weight is not the only consideration here. It's also where that weight (mass, really) is concentrated, otherwise known as the "moment of inertia." The 18's weigh a few pounds more, yes, but that extra mass is 1" closer to the center of the wheel than that of the 19's. So, in actuality, the moment of inertia of the two wheels may be pretty close, meaning the torque required to start and stop them may be about the same.
So, if you imagine the wheel to be a hollow cylinder for simplicity's sake, the Moment of Inertia of a hollow cylinder = 1/2 x Mass x (Outer Radius^2 + Inner Radius^2). As you can see that as the radius increases, the moment of inertia goes up as square of the radius. The mass increase is just a direct multiplicative factor.
If you assume (again for simplicity's sake) that all the mass is concentrated in a 1" ring around the edge of the wheel (i.e. from 17" to 18" for the 18" wheel and from 18" to 19" on the 19" wheel), and do the math, here's what you get for moment of inertia:
Conversions:
17" = 1.42ft
18" = 1.5ft
19" = 1.58ft
19" rear wheel: (1/2) x 20lb x (1.58ft^2 + 1.5ft^2) = 47.6 lb-ft^2
18" rear wheel: (1/2) x 24.5lb x (1.5ft^2 + 1.42ft^2) = 52.1 lb-ft^2
So, al in all, the wheels should perform pretty closely in terms of real world acceleration, deceleration and handling. Maybe a 1-2 lb reduction in weight for the 18's would bring it to the point of being a wash.
