Let's drop it.
Old Jun 21, 2005 | 07:58 PM
jeepman's Avatar
Let's drop it.
Let’s talk dropping some…
04 coupe. Got some wheels order from James with Creativeautoworks.com, and while I am waiting on those I want to get the G dropped some. I don’t want it dropped any more than an 1”. I like the ride the way it is now, and I don’t want something that will jar your teeth out. However, I wouldn’t mind improvements where they can be made.
With that being said….the most I would want to spend would be around $1K. Since I want a mild drop, I am hoping I won’t have to purchase camber kits.
I either want to go with springs and shocks….or coilovers. As far as springs and shocks I was thinking about D-Spec/H-tech (350z) combo. Looks like those run around $650. So, then I get thinking…if I am going to spend that much maybe I should just go with coilovers, and for those I was thinking about the Tein Basics. However, after some reading and searching here it sounds like those provide a pretty hash ride.
So…any suggestions? Am I on track with just getting the D-spec/H-tech combo? Are there other shocks or springs I should be considering?
Thanks!
Old Jun 21, 2005 | 08:02 PM
sen_jen's Avatar
Meatshake Enterprise
if available: koni yellows/htech, or tein basic's. i'd suggest a camber kit if you decide to lower the basics more than the recommended Tein setting.
Old Jun 22, 2005 | 12:20 PM
jstwong's Avatar
Seems that you want a specific / controlled drop, and if that is the case, then going with a coilover is your best bet. I went with the HKS Hipermax LS coilover for my sedan, and only dropped 1" F / 0.75" rear [I was expecting the springs to settle but they really have not done much]. The point being is that the installer was able to get my alignment back to within factory specs. w/o having me resort to getting a camber kit.
Old Jun 22, 2005 | 01:46 PM
jeepman's Avatar
well...after some reading here, I am thinking about doing the H-techs for the Z and Koni shocks. I was considering the tech-d shocks but from the reviews here it seems everyone likes the koni's better.
Old Jun 22, 2005 | 01:55 PM
kenchan's Avatar
yeh, keep reading....
same questions asked over and over again....
Old Jun 22, 2005 | 02:08 PM
jeepman's Avatar
hmmm...not really. not too many reviews on the koni vs the tech-d's, and not much information on the H-tech's for the Z and koni shocks together.
Old Jun 22, 2005 | 05:24 PM
areddy14's Avatar
save up and get the tein cs, i have heard nothing but great stuff about it.
jsimonk
Dec 22, 2023 03:49 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
joedaddy1
Jul 28, 2015 02:58 PM
