HELP - Upper control arm torque specs?
Old Jul 8, 2005 | 12:54 PM
townsley's Avatar
Question HELP - Upper control arm torque specs?
Apologies for the double post in the Sedan forum:
I'm in the middle of upgrading my suspension and just realized I don't know the torque specs for the front upper control arm (the one with the cotter pin). Does anybody know this???
Old Jul 8, 2005 | 01:09 PM
GeeMan's Avatar
Townsley: PM me your e-mail address and I'll send you the specs from the technical manual.
Old Jul 8, 2005 | 03:42 PM
kenchan's Avatar
Why don't you just post the torque specs here?
Why are some of you so protective of your info? SHARE your info and experience!
that's what these forums are about... no?
I just hand tightened mine gently and put a new cotter pin on cause it wasn't
that tight when I removed the nut..
Old Jul 8, 2005 | 10:52 PM
lucky_menehune's Avatar
Nut with cotter pin:
54-63.7 Nm
5.6-6.4 kg-m
40-46 ft-lb
Two bolts at pivot point:
50-60 Nm
5.1-6.1 kg-m
37-44 ft-lb
Old Jul 8, 2005 | 11:19 PM
kenchan's Avatar
Thanks.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
j_mullet
Aug 26, 2015 10:49 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
