Analysis of Koni Coilovers
Old Aug 9, 2005 | 07:14 PM
vodkarocket's Avatar
Modded Member
Here is the information regarding Koni's K Sport Coilovers:
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology featuring its 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
* Default spring rate F: 15kg R: 13kg
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
Would this be a good fit for a G35 sedan? Not too soft or too stiff? I am deciding between these and the Tein Basics.
Old Aug 10, 2005 | 01:05 AM
dklau33's Avatar
I think you need to revise your title. The Ksport coilovers are in no way made by Koni or affiliated with Koni in any way.
Old Aug 10, 2005 | 12:14 PM
Modded Member
Really? I found out about them through eBay, and they were called the Koni Ksports...
Old Aug 10, 2005 | 04:28 PM
g35sedamn's Avatar
ksport is deffinatly not a koni product. k sport is made in the same place as d2's are made, or so i heard from 240sx forums. i've heard good and bad things about them some love them some hate them.
Old Aug 10, 2005 | 04:41 PM
Modded Member
Gotcha. I've ridden in Maxima's with the D2 coilovers and they had excellent ride quality and adjustability.
Old Aug 10, 2005 | 05:13 PM
kenchan's Avatar
holly crap. might be good if you're constipated...
Old Aug 10, 2005 | 05:36 PM
Modded Member
With the Ksports, you have your choice of various spring rates- these are their standard though (for the 350z).
Which spring rate would you suggest for a firm ride, but not jarring ride?
Old Aug 10, 2005 | 05:59 PM
dklau33's Avatar
Here's two threads from my350z.
http://www.my350z.com/forum/showthre...ghlight=ksport
http://www.my350z.com/forum/showthread.php?t=135052
Old Aug 10, 2005 | 06:17 PM
Modded Member
Thank you dklau, for the links.
Looks like it will be the Tein Basics for me afterall.
Old Aug 10, 2005 | 06:39 PM
kenchan's Avatar
maybe 8-9kgf/mm
Old Aug 10, 2005 | 07:16 PM
dklau33's Avatar
maybe 8-9kgf/mm
Yeah, that's why I'm eyeing the HKS RS coilovers. Supposedly a good compromise between track and street duty with reasonable 8kg/8kg spring rates. But for ~$1,800 I would expect those coilovers would be able to adjust spring preload and ride height seperate of each other.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
