help on offset for ADR sterling
Hey guys, I just ordered a set of 20 x 8.5 ADR sterlings in the True diamond cut finish. I wanted to get them in a 38 offset, but the shop i ordered them from said they only come in a 40 offset and that the difference between 38 and 40 is miniscule. Do you think that the ADR with the 40 offset would still clear my Brembos and would still look good?
Re: help on offset for ADR sterling
Do you have a sedan or a coupe? My wheels are 38mm, and 2 mm in either direction wouldn't be a problem on my car, then again, I don't have Brembos....
Ivory Pearl/Premium/Xenon/
I have 19x9.5 +17 and 19x10.5 +19 rims coming in 3 months. These will clear my Brembos and still fit perfect in wheel well and suspension.
Some Track 350Zs are running TE37s 19x10.5 +22 and they fit perfect.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
They should fit just fine. I had a set of Privat Fahren's that had 40mm offset. No problems.
BUT they will be VERY tucked in. More so than stock.
I now have 20mm offset F, & 25mm offset rear. This brings the wheels closer to the outside.
BTW: the Nismo wheels for the G are 25mm offset F, & 30mm R.
BillR
BillR
seagrasser
May 3, 2022 09:43 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
