20" Tire Help!
Originally Posted by Chico
It should be fine 'cause there isn't a significant difference in height between the two set ups. But I can't say I am 100% sure if the new width will have any impact on the VDC. My opinion is: it doesn't but you should double check.
Brian, If you want one of the best biting tires out there, I would go with the Bridgestone S03 pole positions just be prepared to be paying for them.
They offer 245/35 20 for your fronts, 275/30 20 and 285/30 20 for your rears.
James
James
Originally Posted by devin
Brian,
what offset are you using for your front and rear wheels? also what size are they?
thanks!
Devin.
thanks!
Devin.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
FS[Canada]: G-Line 18" Black w/Chrome Lip with Tires + TPMS
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
So no LSD on the stock 6MT whatsoever, right?
