installed tein basics. help with camber
Old Aug 23, 2005 | 03:51 PM
yonimation's Avatar
wassup guys, just got my car lowered with the basics.its a 04 g35 coupe. i need to know if the front are going to be ok... also how are the rears. thanks in advance
http://i7.photobucket.com/albums/y27...ion/camber.jpg
Old Aug 23, 2005 | 03:57 PM
vodkarocket's Avatar
Modded Member
I don't know much about the alignment numbers so somebody else will be able to chime in about that.
But, it says you have a sedan so POST UP PICS OF THE DROP!
How is the ride with these? How low did you drop it?
Old Aug 23, 2005 | 04:21 PM
yonimation's Avatar
actually its a coupe. i dont know why it says sedan. im lowered an 1inch all around
Old Aug 23, 2005 | 04:23 PM
ryanwiggum's Avatar
take it back, they probably used to the wrong specs to align the wheels. Make sure they use the data for the Coupe
Old Aug 23, 2005 | 06:05 PM
imalazeeass's Avatar
04 coupe? I thought the spec range is different than what is on your paper..
Old Aug 23, 2005 | 07:15 PM
MEECHIN's Avatar
For the coupe, the camber shouldn't be anymore negative than -1.25º
That's factory specs.
Your rears are fine.
Invest in some front camber arms to bring your camber in more. (more positive)
Handling-wise, -1.5º is good but could add a little more to premature tire wear.
Not sure if they could bring it down even more if you take her back in.
The camber on our cars is pretty much set.
Adjustable Control Arms are necessary if you're a victim of excessive negative camber.
Old Aug 23, 2005 | 07:19 PM
nerdspeed's Avatar
i just got basics installed on my coupe too. i just got my alignment done also, i'll try to remember what my results were also. i pretty much dropped it about an inch all around also, but i'll probably adjust it after i put my rims on this coming monday.
Old Aug 23, 2005 | 08:42 PM
kenchan's Avatar
Alignment wise it looks fine, are you using rear camber rods?
are you sure the corner heights are even left to right?
Old Aug 23, 2005 | 11:36 PM
yonimation's Avatar
anyone else?
heres my car before and after at street image =)
http://i7.photobucket.com/albums/y27...fore-after.jpg
Old Aug 24, 2005 | 12:19 AM
kenchan's Avatar
side shot of your car doesn't help me any for the q's i posted to help you.
goodluck.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
NohoG35revup
Aug 22, 2015 12:13 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
