question on 8.5 and 245/40 ???
Old Aug 31, 2005 | 06:47 PM
yonimation's Avatar
for the G35 coupe can you run 18x8.5 and 245/40/18 all around? whats the good or bad about doing this. i know people always go staggered on tires and rims. thanks in advance
Old Sep 1, 2005 | 03:17 AM
Gthree5 6MT's Avatar
GOOD...for traction (steering)
BAD...for looks, and depending on the offset of the front wheels & if your car is lowered enough, you might rub fender
QUESTION: Why are you contemplating doing so? Is it so you can rotate your tires (and maybe save a little bit of $$$) ? If so, I think your savings won't be significant enough to be worth the trade-off in appearance...at least it wouldn't be enough for me.
But ultimately, to answer your original question...the answer is YES - you CAN run that size all around
Good luck & Enjoy the Ride!!!
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
