lowering question
Old Sep 3, 2005 | 02:25 PM
98intrigue's Avatar
lowering question
I had my Tein H-Tech spings for the 350Z installed professionally last Friday. I've measured all wheel gaps and it seems that the passenger's side of my car is 1/4"(rear) higher and 3/8"(front) higher, compared to the driver's side. It's very noticeable to me and others. Does anyone know if this is normal? I know it is not that hard to install the springs and you cannot mess up the install. So I do not know what would be causing this.
Old Sep 3, 2005 | 02:28 PM
SFLG35's Avatar
FGC President
i think that it prolly needs sometime to settle a little bit
did you get them installed yesterday or a week ago friday
if it was a week ago friday then i would take it back and see what they have to say about it
Old Sep 3, 2005 | 02:33 PM
kenchan's Avatar
them dang "professionals".... even some drunks that work at
Midas are professionals.
it's corner weight...just the way it is on some springs. on my car, each corner is even L/R.
Old Sep 3, 2005 | 03:07 PM
98intrigue's Avatar
I had the springs installed at Racingzone in Orlando on August 26th.
Old Sep 3, 2005 | 03:48 PM
cKy2k's Avatar
i have the same issue with my eibach springs on certain surfaces .... sometimes i cant even stick one finger between the gap and sometimes i can stick 2 fingers between the gap ... its weird ... go to a flat surface and measure it
Old Sep 3, 2005 | 09:42 PM
kenchan's Avatar
ummmmm.... it's suppose to be like that on uneven surfaces. that's normal
Old Sep 4, 2005 | 02:28 PM
b0hr's Avatar
the end of the spring might not be lined up with the notch in the top of the strut assembly
Old Sep 5, 2005 | 11:36 PM
98intrigue's Avatar
ttt. should i contact the shop that did the install? I mean, I can't really see any error in installing lowering springs...but what else could it be?
Old Sep 6, 2005 | 02:03 AM
G35pm's Avatar
Normal. When I had H-Techs, the driver side of the car was lower than the other. Protocav has done a ton of spring installs for Z's and G's and he'll tell you the same thing.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
