Tein HTechs vs OEM springs
Old Sep 10, 2005 | 12:59 AM
dmtx's Avatar
Gents, I'm pretty new with suspensions. I would like to drop my G for a bit so I purchased the G35 htechs (on sale). I have 2003 G35c with brembos. The dealer said that it comes with tuned suspensions/springs. That being said, is getting the Htech considered an upgrade or is the OEM "tuned" suspension better that Tein Htechs? Should I just get a different spring set? You're inputs to this newbie question would be much appreciated...
I would like to lower the G but don't want to suffer the performance of the car.
I found this from one of the posts but don't know what progressive/linear, spring rates, softer/stiffer?, transfer roll stiffness to front means.
Originally Posted by Gsedan35
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260
Stiffer/softer then oem by F+ 5% R-22%
Transfers +27% roll stiffness to front
Old Sep 10, 2005 | 06:46 AM
sdkingka's Avatar
tein h is very very very very good!!!! the first day i drove it, i was very surprised at noticeable drop. (i parked next to stock ones and the difference is big, not only bc of height, but also bc the front drops more than the back, making the car look more balanced. ) ride quality is MUCH more tighter than the stocks, and it lets you corner like a maniac on fwy interchange bridges.
i bought the springs bc i hated that big gap in the front, and also i wanted to save my oem shocks. ride quality was beyond my expectations. not too harsh, not too soft. this should be a factory option...
Old Sep 10, 2005 | 10:52 AM
Keith N's Avatar
I have the Tein 350Z H Techs springs. It's a very nice subtle drop of approx. 0.7". It lowered the wheel gap, which appeared to be more pronounced with the 19" on. I don't have any camber issues. I like the slightly firmer ride and improved handling. The car isn't dropped to the ground, but IMO it looks nice & clean. I'm really happy with this mod.
Old Sep 10, 2005 | 12:31 PM
plux79's Avatar
Which do you guys prefer tein h techs or eibach pro kit?
Old Sep 10, 2005 | 01:13 PM
G-ThreeFizzle's Avatar
So no one has any camber issues with this setup?
Old Sep 10, 2005 | 02:55 PM
cungkpham's Avatar
i've have camber issues... i have negative wear in the rears after roughly 5000 miles on the tires. but the majority of it could possibly be becasue of my drive back home from texas to cali with some luggage in the trunk.
Old Sep 10, 2005 | 05:33 PM
sdkingka's Avatar
tein h : still feels like a luxury car, a little stiffer feel than stock. ride feels very much like a bimmer. (my bro's 5 series w/ sport package has very similar ride quality.)
eibach : very harsh, sporty ride. ride feels very much like 350z. (too stiff for me, bc my g is a daily driver.)
i really recommend tein h for g35, if you are concerned about the camber issue. ( front - 0.6" / rear - 0.3" ) tein h for 350z may or may not give you the problem, i heard.
Old Sep 10, 2005 | 06:32 PM
sdkingka's Avatar
stock
Attached Thumbnails Tein HTechs vs OEM springs-1-.jpg   Tein HTechs vs OEM springs-.jpg
sdkingka's Avatar
teins
Attached Thumbnails Tein HTechs vs OEM springs-t.jpg   Tein HTechs vs OEM springs-t-1-.jpg
Old Sep 15, 2005 | 02:09 AM
drunkin master's Avatar
I have 20x8.5 f & 20x10 r with 245/35 & 275/30 rear. I am thinking of dropping the car with tein h. how much for springs & intall. Will I have any issues on rubbing?
The space I have is about 2 fingers between tire and fender (front and back) I don't want to go too low and don't want the front to be lower than the back. I like an even look. Can anyone of you give me input...
Check out my black baby... http://www.cardomain.com/ride/2115407/1
Old Sep 15, 2005 | 11:58 AM
Teeter's Avatar
Most of the positive reports I've heard have been from the 350Z H-Techs on the G's. The G35 version of the H-Tech's has a strangely soft rear spring rate (260?). Probably rides smooth, but seems like this would promote understeer. I doube aggressive drivers would like that set up. (But what do I know? ) -T
Old Sep 15, 2005 | 05:00 PM
BrianlG35C's Avatar
Ohio G Club Member
I love my G H-Techs, the ride is great even with 20s.
Old Sep 15, 2005 | 06:43 PM
Teeter's Avatar
THAT......is a great looking car! (Can't find the "drool" emoticon.) -T
reavensf
Sep 17, 2015 11:30 PM
andresito7
Aug 1, 2015 04:53 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
