Camber Kits Cusco/Stillen/ Kinetix???????
Old Sep 12, 2005 | 11:59 AM
WhiteSkylineSF's Avatar
can anyone help???? i've got an '05 coupe 6mt... just installed the tein flex and need to camber adjust... what are your experiences with camber adjusters and which do you think would be best for buck... like i know they're all made from different materials but do you think that they're all just as strong??... like am i just paying for the name??... here's what i found... Cusco front $425/ Stillen set $1564 (front & rear)/ kinetix set $700 (front & rear)
i appreciate any help i can get... thanks...
Old Sep 23, 2005 | 04:14 PM
riceboi704's Avatar
I am in the same situation. I installed cusco zero 2 coilovers and looks to be like I am going to need some camber adjustmensts in the rear. I was quoted $425 for SPC camber kit installed...and my question is, are there any way you can get cheaper ones? and will it make a difference?
Old Sep 24, 2005 | 12:52 AM
caskyline's Avatar
Former Vendor
The SPC camber kit for the rear works just fine.It also includes toe bolts.From what I found it's the best price.Unfortunatly there are not many choices for the front.I happened to use the cusco a-arms.They worked for me.I did all the install myself.This suspension is easy to work on.The alignment was done by West End Alignment.
Old Sep 24, 2005 | 01:08 AM
riceboi704's Avatar
Yeah, I think I am gonna get mine done at west end this coming week too. From my experiences so far and from what I've heard from other people, West end is probably one of the best alignment shops.
Old Sep 24, 2005 | 02:16 AM
imalazeeass's Avatar
wow I was charged $60 to install the spc kit. The entire kit is only about 200 somethin bucks.. so 425 is a bit pricey..
Old Sep 24, 2005 | 04:03 PM
riceboi704's Avatar
where is this shop located?
Old Sep 26, 2005 | 05:54 PM
TouvanS's Avatar
Camber kit
Does anybody know if the just buying the camber rear/toe bolts for $90 does the job, or is it necessary to buy an entire kit???
Old Sep 27, 2005 | 01:35 AM
caskyline's Avatar
Former Vendor
If you are dropped only 1 inch you should be ok.You do want both. Look around, I think you can find them cheeper than $90 ,unless that is the installed price.
Old Sep 27, 2005 | 01:56 AM
Its on lowerazusa and rosemead. I live in socal...
Old Oct 25, 2005 | 05:44 PM
IAPDirect.com's Avatar
Not sure on the front kit as SPC still has theirs in development but the SPC rear camber arms with toe bolts are available for approx. $219 shipped. I wouldn't pay much more than $100 to install them as the camber arms install fairly simply and the toe bolts require just a bit of hole elongating. You can find them at: www.camberkit.com Hope this helps.
Old Oct 27, 2005 | 03:44 AM
ryanwiggum's Avatar
My front L and R camber are @ -1.8, how much positive camber can the cusco's add?
Old Oct 27, 2005 | 08:10 PM
300zx2G35's Avatar
No idea whats going on
im using the SPC rears (www.iapdirect.com)and 350evo fronts. the 350evo (www.350evo.com) fronts are a bit pricey but def worth it IMO for the adjustability and quality of them. Plus the customer service from both IAP and 350evo was awesome!
Old Oct 27, 2005 | 11:54 PM
wreck's Avatar
Running for his life!!
I ordered some SPC Toe bolts only (have LSD camber bar's from a long time ago) and 350evo front arms yesterday and both iapdirect and 350evo shipped it out the next day. Any company that can ship next day gets an A+ in my book. I can't wait until I get them and install them. Hopefully I will be back to spec.
Old Oct 28, 2005 | 12:10 AM
Alan's Avatar
from what i have read, cusco fronts will add on .5 to .8 i just had mine installed, and visualy, my front wheels are waaaay less angled. i will give westend a call tomorrow!
Old Oct 28, 2005 | 12:28 AM
wreck's Avatar
Alan, tell me how your car turns out after taking it to west end. I called them today, but they only work on the weekdays which sucks, because I work during those hours. I was going to have them install the arms and do the alignment.
(take a peak if they have a balancing machine too.. Hunter brand).
