Damn Rims, help..
Old Sep 25, 2005 | 08:37 PM
trackmagic's Avatar
Damn Rims, help..
So i park on a hill outside my house and i forgot to pull the e-brake but had it in first gear. I went inside for about an hour and come out to find the car popped out of gear. The good news is that the wheel hit the curb and stopped it from rolling down the hill, but the bad news is my wheel is curbed pretty bad.
My question is what should I do because I am going in next week to get the rims powdercoated. I have the 05' 19's by the way. Should I just leave it or what?
Old Sep 25, 2005 | 09:23 PM
Msedanman's Avatar
O.F. Administrator
UGGG, I bet you won't forget the brake again.....
The powder-coating people should be able to fix up the curb rash b4 coating.
C.
Old Sep 25, 2005 | 09:27 PM
sage's Avatar
Get it repaired at the dealership or some local shop. It will probably cost you around $100/120 depending on the place you take it to.
You are very lucky that all that resulted was a messed up rim. I understand that your gear will catch your car but no reason to ever not use your e-brake. If I were you, I would be very happy that it is only costing you a hundred bucks. Could have been much worse...
Old Sep 25, 2005 | 09:31 PM
G35Vision's Avatar
"Get it repaired at the dealership or some local shop" DO NOT!! Have the Powder coating place repair it. If you take it to a place that fills it with something other then metal . The coating shop will only have to remove the filler & repair it & charge you again for the same repair. Powder coating can not stick to fillers. .. Good luck
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
