18” Wheel OEM Part#
Old Sep 29, 2005 | 07:21 PM
GIIIV's Avatar
18” Wheel OEM Part#
I’ve search the forum and could not find answers to my question. I would appreciate if someone can help me.
I got my tire repaired at America’s Tire Co. in Carson, CA. In the process of mounting/dismounting my tire, the rim got damaged the rim. After some b!tching, America’s Tire Co. will be replacing the rim with a new oem rim at no cost to me. Considering that incident, I lost my confidence/trust in them so I decided to do some research to make sure they order the right rim. In the process, I found out that the front rims and the back rims have different part numbers.
Front: 40300AL425
Back: 40300AL426
From my understanding all 4 rims are the same size 18x8. So why the different part numbers? I’ve contacted the dealers to ask this question and no one could give me a straight answer (no surprise). Some say that the offset is different and others say that there is a “****” that makes the fronts different from the backs.
Pls. help to shed some light on this.
Thx in adx.
Larry
Old Sep 29, 2005 | 07:29 PM
redwillow's Avatar
20 Year Member
whoever told you there is a "****" is correct. The front and rear rims are the same dimensions, but the fronts have a hole in the middle that will accept the front fitment bolt. This bolt keeps a rear rim from being rotated to the front due to the diff in front & rear tire sizes.
If you want to remove the front fitment bolt from your car you will be able to use a rear rim on the front with no problem.
so actually, they can order either part number and it will work....if you want to put a rear rim on the front, just take off the front fitment bolt.
Old Sep 29, 2005 | 10:28 PM
GIIIV's Avatar
Redwillow,
Thanks for the quick response!
Any pictures by any chance?
Thanks again!!!!
Old Oct 2, 2005 | 05:49 AM
navi601's Avatar
so is that mean i can put 225/45/18 tires on the rear rims?
Old Oct 2, 2005 | 08:10 AM
binar's Avatar
You sure can
Xfactor
Dec 1, 2019 12:52 PM
EPG35
Aug 16, 2015 04:52 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
SIKKI
Jul 21, 2015 01:55 PM
