SLAMMED. sooooo....camber solution FRONT AND REAR (low cost and acceptable quality)
Old Oct 5, 2005 | 01:36 AM
Raznips's Avatar
I was just reading about camber issues.... and i have decided that i want to purchase camber correction with the tein basics that i'm considering... I'm kind of wanting to go the cheapest route that will get me back in spec if i slam my gcoupe. I dont know exact numbers on inches i wanna drop cause i have seen very few people's cars on here that are as low as i would like to go. I wanna tuck about half an inch of tire... can anyone estimate how much of a drop that would be? What a arms and rear camber adjustment brands should i go with? I just read something about the poor quality of kinetix front a-arms but the good adjustability (all at a low price). I was planning on SPC for my rear camber needs, but i'm open to other options
Old Oct 5, 2005 | 01:45 AM
sen_jen's Avatar
Meatshake Enterprise
you will not be able to achieve a drop likeso with Tein Basics. when you correct camber, your height will be changed as well.
Old Oct 5, 2005 | 02:02 AM
achen's Avatar
With a drop that low, your camber is going to be f*******cked up. I have the front and rear kinetix kit and I was able to get close to spec but it's kinda squeaky... and I can't tell if it's from the front or rear.
Old Oct 5, 2005 | 02:38 AM
Raznips's Avatar
what about this low?
Attached Thumbnails SLAMMED. sooooo....camber solution FRONT AND REAR (low cost and acceptable quality)-slammed-g.jpg
Old Oct 5, 2005 | 08:25 AM
turbomaxima's Avatar
Man with green rock in Vortech
tucking 1/2" tire all around on 20s (probably tucking over an inch of tire on 18s):
pulled all this camber out, back to spec:
Here is my list of modifications:
Kinetix adjustable control arms for front (fixed camber completely), kinetix traction arms/camber arms and SPC Toe bolts (fixed camber 90% in rear - barely in the green). I think I spent just under $1000.00 for everything and installed it all myself. A friend of mine helped me 'eye' it up and get it as good as we thought it could get and then I took it to a wheel shop and they put it on the alignment rack.
I am lowered over 3" on JIC coilovers, to my knowledge Tein Basics won't go that low; Tein Flex will, but not the Basics.
-jason
Old Oct 5, 2005 | 12:22 PM
sen_jen's Avatar
that guy is my friend who lives down the street from me. he had custom springs in that pic. his car has since been raised a bit because of coilovers.
correct, but you have to remove the perch in the rear.
Old Oct 5, 2005 | 02:32 PM
jdbinspired's Avatar
yeah... I did have some custom springs in that pic... here's a recent pic with the coilover on... about 6 more turns until it's lowest point...
with camber kits and slammed... you might have to roll the fenders and even have to go with just 9.5...
Old Oct 5, 2005 | 02:44 PM
sen_jen's Avatar
^ i thought the HKS RS' are at it lowest even after the perch removal?????
Old Oct 5, 2005 | 02:48 PM
IS300TOG35's Avatar
► Matt ◄
damn man, how do you drive that around...
Old Oct 5, 2005 | 05:51 PM
nyckid's Avatar
hey jdbinspired and sen_jen, that black coupe with the 20" GT-C that you guys took pics with, can you find out the offset of his rim, thats how i want mine... does he have 20x9.5 in front and 20x10.5 in back?
not sure what kinda look i will have with +29 in front and +24 in back with those gt-c's of mine...
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
Detailed Image
Jul 29, 2015 08:42 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
