What do I need to resolve camber issues?
Old Oct 6, 2005 | 02:23 AM
No1Better's Avatar
I am going to get the SPC bolts for the front and rear but is that all you need to alleviate the camber problem or are camber arms also recommended...???
I want a one-stop shopping experience on Friday so please let me know what I need...
The car is on Tein S-Techs if that helps...
Old Oct 6, 2005 | 05:17 AM
No1Better's Avatar
bump
Old Oct 25, 2005 | 04:13 PM
IAPDirect.com's Avatar
The SPC camber arms with toe bolts is the best kit to use for the rear. Unfortunately, they do not have the front kit available yet (hopefully the first of the year). Check out www.camberkit.com for more info on the rear kit.
PM me if you have any questions.
-Peter
Old Oct 25, 2005 | 04:24 PM
afr0puff's Avatar
Supa Dupa Moderator
You will need A-arms for the front. For the rear, you can get away with just the SPC bolts. Most just do the rear and try to get the front to spec as close as possible. A-arms will probably cost you more than the springs.
chinee
Jun 10, 2024 07:48 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
