OEM 19's rusting! Help!
Old Oct 8, 2005 | 04:00 PM
MAB102501's Avatar
My OEM 19's are starting to rust on the inner part of the rim! Has anyone else ever ran into this problem? If so what did you do and secondly do you think Infiniti will replace the wheels?
My car originally came with the OEM 18's and I bought the 19's from another site member. Will they warranty that if my car didn't originally come with those wheels?
Any input will help!
Thanks!
Old Oct 8, 2005 | 04:07 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Do you have pics?
Old Oct 8, 2005 | 04:09 PM
ScottR's Avatar
Are you sure it's not just discoloration from brake dust? The wheels are aluminum. Uhh, I don't think aluminum can rust. Am I missing something?
Old Oct 8, 2005 | 04:15 PM
MAB102501's Avatar
I'm not to sure... Yesterday I washed the car and the rims. I washed the insides of each wheel as well and if it were discoloration from brake dust it should have gone away right?
Old Oct 8, 2005 | 04:28 PM
chicagokid's Avatar
I have a small amt of that too on the fronts. It does seem like from brake dusts???
Old Oct 8, 2005 | 04:37 PM
G (enie) FUNK ERA
I don't know about the wheels, but I know that when I wash the car or when the car stands outside overnight in the rain, I have a thin layer of rust accumulates on the rotors. Is it possible that's the same kind of rust you're seeing?
Old Oct 8, 2005 | 04:40 PM
LjN_728's Avatar
+1 Brake dust. When you're washing your rims, try scrubbing the area in question. It'll come off...I choose not to clean if cuz nobody ever sees it.
Old Oct 8, 2005 | 04:44 PM
Gee Im Fast's Avatar
Aluminun DOES NOT rust...
Old Oct 8, 2005 | 04:54 PM
jsh198's Avatar
Yes, but it does corrode.
Old Oct 10, 2005 | 05:11 PM
Curt G's Avatar
Isn't that just bearing grease? Comes out from where the rim attaches to the spindle, right? Stuff is tenacious. If anyone figures out how to wash it off, please let me know.
Curt
Old Oct 10, 2005 | 05:18 PM
mephistomyhero's Avatar
That is true. Our rims are an alloy (mostly Aluminum from what I can remember reading). Aluminum doesn't rust, doesn't corrode, but it does oxidizes (somewhat), but that is more of a white residue and only on pure aluminum. I have some brake dust on my rims that are kinda brownish so it looks like rust but isn't really. Get some good Rim Cleaner (I use Maguires and it works decent enough) and you'll be ok. What you are really seeing might also be some of the rust dripping off of the brakes and onto the rims. Again, some wheel cleaner will do the trick.
Old Oct 10, 2005 | 05:29 PM
jinubob81's Avatar
Evil Bastard
corrosion shouldn't look like rust.
Did you go poopy on your wheels? (just kidding)
rub away on it with some simple green or dishwasher soap. It's hard work, but people usually don't do it cause no one sees it. Unless you have your car lifted up and people walk underneath it for inspection all the time.
The 19"s are forged aluminum alloy. I think it is painted and clearcoated. In either case, dealer may or may not warranty. I'm not sure what the warranty says regarding OEM pieces purchased from private parties (OEM parts bought from dealers new are covered under your new car warranty, however).
Good luck in any case.
Old Oct 10, 2005 | 05:32 PM
caskyline's Avatar
Former Vendor
I also get residue on my wheels.It is from the rotors.The inner part of the rotor does not make any contact with the brake pads.So after you was your car,rust does form up quickly on that part of the rotor.Thats why the other day I took off my rotors to paint that inner part with high temp paint sometime this week.This is what I did on my Accord,it works great,no more mess.In the meantime I put my oem rotors back on.
Old Oct 10, 2005 | 05:50 PM
waterp7's Avatar
It is actually your rotor rusting up and leaving oxidized iron caked on your 19s... It is not actually your rims. When your rims are in contact with the rotor all the time, it will build up solidified rust onto your rim over time.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
5ATSEDAN
Sep 1, 2015 12:54 PM
jdubin94
Sep 1, 2015 12:17 PM
