Wheel Spacers Pros and Cons ??
Old Oct 10, 2005 | 12:19 PM
myGspot's Avatar
I'm thinking of getting either a 10mm or 15mm spacer for my oem 19s to push them out a bit and make them flush with the fenders.
i been looking around different site on spacers and some seem to be very cheap and some like H&R are about $160.
Anyone ever dealt with spacers before and know the difference? From what i see the H&R has studs built into it??? i dont know what they are for? Because other spacers just go between the wheel and the hub.
any opinions suggestions will be welcome.
Old Oct 10, 2005 | 02:17 PM
kenchan's Avatar
im running Kics
Old Oct 10, 2005 | 02:20 PM
myGspot's Avatar
Originally Posted by kenchan
im running Kics
?? what
Old Oct 10, 2005 | 02:24 PM
Triple8Sol's Avatar
Depending on how thick you go, you might need to get new hub bolts. Some spacers like H&R are more expensive b/c they're hubcentric. That's the ONLY way to go when it comes to spacers.
Old Oct 10, 2005 | 02:39 PM
myGspot's Avatar
Yes i did notice that the H&R spacer is hubcentric, but will it work with OEM wheels and oem hub?
Old Oct 10, 2005 | 03:00 PM
Andy2434's Avatar
Interesting topic . . . Will the addition of the spacers affect the VDC and/or the suspension geometry and handling?
Old Oct 10, 2005 | 10:23 PM
Triple8Sol's Avatar
Common sense tells me that's definitely possible. I'm not sure how sensitive the VDC is, although with the offsets/stagger that I'm running (along w/alot of others on the boards), I doubt it matters anymore...
Old Oct 11, 2005 | 03:02 PM
RashMan1450's Avatar
hey if you get spacers, you also have to get longer lug nuts right?
Old Oct 11, 2005 | 03:15 PM
myGspot's Avatar
been asking around and seems like there are some spacers that use existing studs or there are some that come with their own.
My main thing is to get a wider stance from OEM 19" wheels which should give me better cornering and help me out with autoX.
I somehow doubt it that vdc has anything to do with spacer.
Old Oct 11, 2005 | 04:33 PM
sen_jen's Avatar
Meatshake Enterprise
im running Kics
imo, the best spacer available for our car. Kics Project wheel spacers. these already come with longer studs. JDM product too.
Old Oct 11, 2005 | 05:39 PM
firefox's Avatar
I'm running 15mm kics spacers for the past 9 months with no issues. I also got the 15mm hub centric ring for the front wheels to prevent any vibrations.
I had H&R hub centric spacers on my old Trans Am. It's good product. But I was a dummy and tried to take out the studs myself. Long story short, I broke the stud and had to bring it to the shop anyway to get the thing "pressed" out.
Needless to say I didn't want to mess with getting longer studs this time. Also, in case I sell the car, I didn't want to get the car re-studded with shorter studs (so that I could remove the spacer).
Old Oct 11, 2005 | 05:52 PM
myGspot's Avatar
^^ where did you get the KICS from?
sen_jen's Avatar
^ (above this guy) and this is the reason i stress Kics Project spacer's are the S.hit! good deals mang. many of my friends are running these too with no problems. 240's, Hachi's, Supras, widebodies, etc. awesome product.
call up OptionImports @ 909-595-7765
Old Oct 11, 2005 | 06:08 PM
firefox's Avatar
Actually, that is where I got my spacers from. http://www.optionimports.com/import-store/kiprwhsp.html
However, you have to call to get the hub centric rings (they aren't on the website). Pretty good customer service.
TheJanitor6203
The Q - Spot
Oct 6, 2015 10:13 AM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
lemmy999
Jul 25, 2015 12:13 PM
