G35 Factory/Oem Wheel Sizes & Offsets
Rating: Thread Rating: 4 votes, 5.00 average.
Old Mar 24, 2012 | 06:54 AM
  #106
NYT's Avatar
NYT
Originally Posted by RastaManMax
You realize that the OEM G35 rays are 8" front and 8.5" rear right?
Nope... missed that in his post
Going wider on the OEM size rims is tough because it's not easy to find a width/sidewall combination that says within a reasonable range of the OEM wheel diameters (so it doesn't mess with the VDC) and there's limited tires actually available in those sizes to match front and rear.
The OEM wheels are pretty decent, but it's not as easy as just throwing on tires that are 10 or 20mm wider.
Old Apr 4, 2012 | 12:53 AM
  #107
heftylefty58's Avatar
FYI, the specs for 6 spoke wheels on the 2004 G35 Sedan are shown on page 9-8 (ie, chap 9, page 8) of this doc:
http://www.infiniti-techinfo.com/ref...finiti-G35.pdf
Here's what I see for my sedan:
17x7
offset: 45
The info in the original post pertains to the Coupe only...not the Sedan:
17" 6 spoke (model??)
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
Old Apr 6, 2012 | 03:47 PM
  #108
betoiniguez's Avatar
Hey guys. Yes im new on this website and i see how u help each other out and im in need of help!
I have a 03 6mt coupe with the 18' rays.
Bought some nice 20' and they dont fit on the front because the calipers... I think they are 40 mm not sure. What should i do, buy spacers with built in studs or spacers with longer studs and whats the offset i need? Thanks!
Old Oct 15, 2012 | 07:43 PM
  #109
cninham's Avatar
I have taken all four wheels off my vehicle, here is the tire and rim info:
Infinity G35 Coupe, 2003
Tires front: 225/50R17
Tires rear: 235/50R17
Rims front: 17 x 7.5 JJ, W237
Rims rear: 17 x 8 JJ, W240
I hope this helps other people.
Thank you -- Cameron
Last edited by cninham; Dec 21, 2012 at 02:49 PM. Reason: updated with correct tire and rim info
Old Dec 18, 2012 | 09:14 AM
  #110
hiepness's Avatar
Yeh i was wondering what the stock suspension can handle without rubbing etc?
because im looking to buy a good set of rims that have dimensions
F: 18x9.5 +19
R: 18x9.5 +14.
Will this fit my V35 coupe 2004 without modifications such as gaurds or spacers?
Thanks.
Old Feb 14, 2013 | 08:30 PM
  #111
parthur's Avatar
Hello everyone! I did search and did not find much... So here I go, my uncle is giving me away 4 ipike 225 60 R17 snow tires for free, he sold his ex35 and has no use for them, now mine G35x -> 225-55, R17, can I use those no problem... I used the calculator but says that the difference is more than 3%, anyone know if thats a problem?
Thanks
Old Feb 15, 2013 | 07:48 PM
  #112
aaraujo88's Avatar
I am looking for the 2007 Infiniti g35x factory rims, do you know where I can get them.
Old Feb 25, 2013 | 07:03 AM
  #113
Akuei0625's Avatar
nice info.
Old Apr 22, 2013 | 03:05 PM
  #114
JerSoPhresh's Avatar
Looking to get spacers on stock ray 19s. Lowered on Tanabe df210. Anyone know what size spacers to go with since I'm sitting pretty low? Trying to avoid fender rolling.
Old Jun 8, 2013 | 02:07 AM
  #115
Em1635's Avatar
I wanna get bigger wheels on the back,, Dealership said its not possible but i know it is, does anyone have any ideas???
Old Jun 8, 2013 | 11:48 AM
  #116
Adil_G35's Avatar
When you say bigger what do you mean? Are you talking about diameter or width? Or both?
Either way you can go bigger. But you'll also most likely have to get different tire sizes. And you may have to roll fenders depending on what size you get.
Old Jun 8, 2013 | 12:55 PM
  #117
Xet's Avatar
Xet
did you read through the thread even? or the forum in general? This has been answered mannnyyy times before
Old Jun 8, 2013 | 03:59 PM
  #118
Adil_G35's Avatar
Lol I was in a generous mood so I tried to avoid saying that lol
To answer his question, first of all, the dealer saying the you can't get bigger wheels is idiotic. Of course you can get bigger wheels and smaller wheels. But just know that changing the wheel size might affect your chances of re using your same tires. You may have to buy Tires as well. If you change wheel diameter you'll have to change tires for sure. Idk why you asked such a simple question. Have you never seen cars with aftermarket wheels? Well they changed their wheel sizes. Why can't you?
Old Jun 9, 2013 | 03:37 AM
  #119
Crack3r's Avatar
Question. I have a set of 19x8.5 and 19x9.5 front and rear, and I've already bought a pair of 255/40/19 for the rears. I don't really want to have a stretched look, I'm more so looking for a regular looking tire. So for the front, could I run 225/35/19? I don't really agree with having a smaller tire in the rear than in the front...I want the same look all the way around. It's really hard to find any pictures of anyone running a set up like this. Any advice would be funtastic!!
Old Jun 25, 2013 | 06:22 PM
  #120
totemg35's Avatar
i did a quick scan through some replies, but has anyone put a/m wheels on their 03 35 coupe that has the brembo package?
i want to, but i'm not sure what kind of offset, i want 18's, just a flush look, thanks.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
