Mysterious tire pressure drop
Old Oct 19, 2005 | 05:39 PM
dirrtybear's Avatar
raises all-in
The other day, my tire pressure monitor light lit up.
I checked the pressure of all 4 tires, and they were all at 28 psi. I normally fill them at 33 psi.
It has gotten colder recently. Does temperature affect tire pressure readings? Should I add air, or leave them as is (assuming that the PSIs will read lower than what they actually are)?
Old Oct 19, 2005 | 08:30 PM
jgainnm's Avatar
Short answer is cold weather causes a drop (theoretically 1 psi for 10 degrees) and you should refill. There's a couple of more detailed discussions going on in the coupe forum.
Old Oct 20, 2005 | 08:37 AM
Coach's Avatar
jgainnm is right on - the 1 psi per 10 degrees F is generally pretty accurate. The average tire can also lose 1 psi per month just from air bleeding slowly through microscopic pores and rim leaks. If you aren't on top of your pressures you could easily lose 3 or 4 pounds through the summer, and on a really cold fall morning find yourself down by 3 or 4 more. Pressures should always be set on a cold tire.
jsimonk
Dec 22, 2023 03:49 PM
JoeMac
Aug 20, 2015 10:17 AM
Jnm07
Aug 6, 2015 03:03 AM
joedaddy1
Jul 28, 2015 02:58 PM
