Tire size help!
Old Aug 3, 2015 | 02:46 AM
Jnm07's Avatar
Tire size help!
What's up guys. I got an 04 g35 coupe and I just bought a set of rims. 19x9.5+12 / 19x11+15. For the front I decided to go with 245/35. For the back I'm still deciding whether or not I should go with 255/35 or 275/35. Im not gonna drop it too low due to bad roads here lol. What tire size is better with a slight drop? Thanks!
Old Aug 3, 2015 | 03:31 AM
HypedAndy's Avatar
id say get the 275
Old Aug 3, 2015 | 09:42 AM
VenomGT9's Avatar
You might want a 275/30 just to avoid rubbing issues and it will sit about the same height as a 255/35.
Having not seen your car nor the wheels it's hard to be exact.
Old Aug 3, 2015 | 01:33 PM
Jnm07's Avatar
Thanks! I'll post some pics after work. But I got brembo brakes on if that helps.
Old Aug 5, 2015 | 10:31 AM
gary c's Avatar
Fronts aren't an issue you can run 245/35X19 but the rear could be a problem. The 19X11 with that offset will require wheel well work and smaller than normal tires for the coupe along with a less than desirable camber setting...Gary
Old Aug 5, 2015 | 10:33 AM
Lartytiejdke3's Avatar
275s will most likely rub if dropped enough or not enough camber is ran
Old Aug 5, 2015 | 12:26 PM
VenomGT9's Avatar
Perhaps he's doing a massive, dare I say insanely debatable amount of pulling and rolling on those fenders??? We just don't know!!!!
Old Aug 6, 2015 | 01:57 AM
Jnm07's Avatar
Thanks for the reply guys. I'm thinking about going with the 255/35/19. I'm planning on going with drop springs too. Tein s tech or eibach pro kit. Any suggestions?
Old Aug 6, 2015 | 02:41 AM
g35fnatic's Avatar
Go big and do coilovers. Springs will just mess your suspension up longterm wise if you dont upgrade the struts & all.
You can get some cheap coilovers which are known for the best "bang for your buck" around the G community which would be BC coilovers.
Old Aug 6, 2015 | 02:47 AM
Jnm07's Avatar
That makes sense. I've heard a lot of good reviews about bc coils, but what about tein basics.. Are they any good?
Old Aug 6, 2015 | 02:51 AM
g35fnatic's Avatar
Tein are good. But I believe bc are cheaper. If you're a regular driver that just wants the look of a lowered car, than bc's will do just fine. If you're looking for performance then get sway bars. I felt more of a difference with my stillen sway bars than my bilstein coils.
Old Aug 6, 2015 | 03:03 AM
Jnm07's Avatar
It's gonna be a daily. Nothing track related. I live in Hawaii. And the roads are not that good lol on top of that its a really small island and there's not enough road to cover. but yeah Ima look into bc coils and see what I can do. Thanks bud!
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
mryogi
Aug 14, 2015 07:58 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
