What is the best offset and width for TE37 on our car?
Old Nov 2, 2005 | 11:56 AM
drtech's Avatar
People seem to have different offsets when I searched...would like to know what look the best.
Thanks
Old Nov 2, 2005 | 12:24 PM
truplay8's Avatar
THE BATMOBILE
check the classifieds there is a set in there for a pretty good price
Old Nov 2, 2005 | 12:35 PM
sen_jen's Avatar
Meatshake Enterprise
+22 all around with 19x9.5" ff 19x10.5" rr.
Old Nov 2, 2005 | 08:25 PM
drtech's Avatar
If they are 8.5 and 9.5, what should be the offsets?
Please forgive my dullness, what is the effect when the offset is smaller?
Old Nov 2, 2005 | 08:40 PM
sen_jen's Avatar
this offset can be applied to 8.5/9.5" width's as well.
Old Nov 2, 2005 | 08:49 PM
drtech's Avatar
But I saw someone with larger offsets, so that will be less agressive?
Old Nov 2, 2005 | 10:33 PM
XLR8SN's Avatar
Lower number offsets=wheels pushed to the outside & closer to the fender lip.
Higher number offsets=wheels more tucked under the car towards the center
The lower number usually termed as "more aggressive", choices of tires and rolling or not rolling fender lip comes into play.
Higher number offsets tend to be "more conservative" but opens up room to drop your car lower without rubbing and need to roll fenders.
Lower offsets also adds more stress to the bushings, endlinks, bearings, and other moving mechanisms due to the center of weight shifting to the outside...out of spec.
+22 on the 9.5 and 10.5 clears big brake kits (BBK) and also sets the spokes to be a little concave. If you want the car to look a little more "aggressive" then save and get the 9.5 fronts and 10.5 rears in the +22 offsets. If you run 275, depending on the height of the vehicle...you might rub a little in the rear.
Old Nov 20, 2005 | 02:41 PM
WaLLy's Avatar
drtech, hey im in the same boat is you're in lol
i was wondering what offsets do and i'm also looking into getting the TE37.
have you had any luck so far in getting them? if so, any help would be greatly appreciated.
Old Nov 20, 2005 | 05:38 PM
Teeter's Avatar
Thanks
Can you clarify "our car"? Different offsets for Sedans and Coupes.
Old Nov 20, 2005 | 11:27 PM
drtech's Avatar
sorry....i mean for coupes
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
