19 X 7.5 OFFSET 44 will this fit?
Old Nov 26, 2005 | 01:09 PM
Sportcoupe35's Avatar
20" wheels with OFFSET 44 will this fit?
Read ahead
Old Nov 26, 2005 | 09:08 PM
kenchan's Avatar
on a coupe? (since your name is sportscoupe35).
On this car, you will want to look for wheels that are 8-9" in width for
front and 8-10.5" in width for the rear. the factory wheels are 8" width
front and rear...
215/35/19 will be too narrow even for front and the vehicle load will be
too much. on a 215/35 tire.
Old Nov 26, 2005 | 09:11 PM
kenchan's Avatar
well, I should say 8" width for the 18's.
Old Nov 27, 2005 | 06:56 PM
Thanks for the information.
How's this for a setup:
20x8.5 fronts and 20x10.5 rear wheels.
245/35/19 front tires and 275/30/19 rear tires.
I have a NON-BREMBO 04 G35 Coupe with the factory 18" wheels currently.
I have my car lowered with the OEM 350Z springs which dropped it about
1/5" or a little bit more.
These wheels have a 44mm offset.
Will these fit my car with just putting them on or would I need spacers or anything like that?
Thank you
Old Nov 28, 2005 | 01:44 PM
kenchan's Avatar
the "20" in the 20x8.5 means 20" diameter.
The "19" in the 245/35/19 and 275/30/19 means 19" diameter.
so you'll need to look for either 19" wheels or 20" diameter tires.
Old Nov 28, 2005 | 08:49 PM
Yeh I meant 20 not 19. Sorry about that mess-up
Old Nov 28, 2005 | 09:27 PM
I didn't mean 19" tires...I meant 20"s....I had temporary A.D.D.
Would it fit?
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Machine Head
Sep 4, 2015 07:22 PM
