same wheel, same car, same offset, so why is it different?
Old Dec 1, 2005 | 01:22 AM
IS300TOG35's Avatar
► Matt ◄
To add to my confusion on offsets see if you can solve this one. both me and DSSkyline have 19x10 roja formula 7s in a +30 offset in the rear. Here is a pic of of wheels side by side at the same angle. It is evident that why wheel is pushed out more but my question is why? I have several pics of both his car and mine comparing this and in every shot it seems my offset it lower. The only difference is mine are silver, his gmetal. see for yourself. what is the reason for this?
His on left, mine on right
Old Dec 1, 2005 | 01:55 AM
manh3's Avatar
It's probably due to the drop, different springs. He really needs an alignment way to much negative camber.
Old Dec 1, 2005 | 01:56 AM
Will Pwr's Avatar
Yeah, looks like its due to camber
Old Dec 1, 2005 | 07:43 AM
vrsc's Avatar
^^^Camber adj.
Old Dec 1, 2005 | 08:51 AM
truplay8's Avatar
THE BATMOBILE
cause he is that much better then you
Old Dec 1, 2005 | 10:50 AM
Chico's Avatar
hmmm...yeah it looks like camber is an issue but even then it looks like the offsets and possibly the widths are different. Have you looked on the back of the wheels to check the wheels width and offsets? or is he going by what the seller told him?
Old Dec 1, 2005 | 05:27 PM
kenchan's Avatar
yep, as above, the car has a lot of neg camber. if you look near the
bottom half of the wheel, the offset is very similar to yours.
Old Dec 1, 2005 | 05:35 PM
Triple8Sol's Avatar
I just wanna be the 10th guy to say it...just look at the camber...
Old Dec 4, 2005 | 01:33 AM
skeleton_cru's Avatar
Sedan
I'll be the 11th, it's the camber.
Old Dec 4, 2005 | 01:51 AM
Habib77fm's Avatar
well before i read the posts on camber. I was going to say "he had his fenders flared" or "he used his lucky spacers" but im going to have to go with camber.
Soumilg
Jul 18, 2015 12:33 PM
