how to take off the lug nuts?
Old Dec 15, 2005 | 10:39 PM
achen's Avatar
Originally Posted by smokedhen
what tools do I need to loosen the nut? I don't even know who tightened the damnnn lugnut. All I have is a torque wrench, which is useless for loosening, and the L-shaped crap they give to loosen the lug nuts with. Would I need a power tool to take the lugnuts back off?
I don't even have a larger socket size to try that hammering method as akrus suggusted.
taking this job to a store would be much easier, but it's not worht the money. Since the whole process isn't that hard, I would much rather do everything myself so it can be a learning process. I just can't loosen that lug nut....aaaaaahhhhh
The L shaped bar that comes with the car sucks! It's not long enough to give you any leverage. I use one of those X-bars and it works well.
Old Dec 17, 2005 | 10:03 AM
lelg35's Avatar
7+ hours to remove the lug nuts? I think that's a new record. But, I'm glad you got them off. Now, use your "new" torque wrench to retorque your wheels everytime after someone else touches your wheels (for service, etc). I always do. The minute I get home after a service visit, I loosen the lug nuts and retorque them to specs. I don't trust others will be as careful with my car.
Old Dec 17, 2005 | 11:07 AM
johnadlertech's Avatar
Originally Posted by kenchan
you can use 80 or 90lbs/ft. i use 90.
I thought it was more like 25? I think on my factory locking lugnut package it states 20.
Old Dec 17, 2005 | 03:25 PM
Graphite G35's Avatar
spray wd40 on it and then before you lift it put the L wrench parallel to the ground and use your body weight to move the nuts and then lift the car and you can take the nuts off with your arm power.
Old Dec 17, 2005 | 03:32 PM
akrus's Avatar
25 is way too low. 85-90 is right. Do not drive if you only have them torqued to 25 ft/lbs.
Albert
Old Dec 18, 2005 | 02:43 AM
abcdefGGGGGG's Avatar
you could also use your torque wrench to loosen the lugnuts.
so you bought a discontinued torque wrench? make sure its good. these are precision tools and they need to be cared for. set it to the lowest settings when your done using it.
Old Dec 18, 2005 | 01:19 PM
Socal 4's Avatar
I usually do the no-no method.....
With the car on the ground, line the L-bar parallel to the ground. Then just put your foot on the bar, and slowly apply your weight on it. I'm very light, so there's been times when I've had to basically stand on the damn thing.
Again, this is usually not recommended, since you run the risk of snapping or cracking something in the process, but I've been lucky so far.
Old Dec 19, 2005 | 01:35 PM
35bills's Avatar
Invest in an electric impact wrench. I've been using one for a few years now and it really saves on time and effort removing the lugs.
Also, invest in a set of impact sockets that have a thin wall or rubberized coating on the outside so you wouldn't scratch up your rims.
Remember when re-installing your lugs to hand tighten first, then use a standard ratchet to further tighten and then use a torque wrench to set the lugs to spec( 80-85 ft/lbs).
Remember, "righty tighty, lefty loosy".
Bill
seagrasser
May 3, 2022 09:43 AM
NyCrAzY
Oct 1, 2015 09:19 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
