I just bought a G35 sedan w/ 20X8.5 245/35/20 in the front and theirs no rubbing, but in the rear it has 20X9.5 275/35/20 and it rubs and shreads the tires when it bounces. PLEASE HELP, someone give me suggestions.
THANKS
THANKS
roll your fender? or sell your tires and see if there's a 255/35/20 available if you dont want to roll your fender. 255mm wide tires would square off the tires to the rims nicely.
Quote:
THANKS
The right tire to use in the rear is 275/30/20. Your current tire is too tall. Also, make sure you got the right offset. If you got less than +42 to +45 you will hit the fenders for sure.Originally Posted by DonSison
I just bought a G35 sedan w/ 20X8.5 245/35/20 in the front and theirs no rubbing, but in the rear it has 20X9.5 275/35/20 and it rubs and shreads the tires when it bounces. PLEASE HELP, someone give me suggestions.THANKS
