Will I Rub!!!! Heelp!
Old Jan 28, 2006 | 01:38 PM
pdjafari's Avatar
OK, So Im about to order some wheels for the coming spring. I need to know IF I will rub.
Here are the specs: Volk Diamond Black GT-7s
19X9.5 +30 / 19X10.5 +24
Here are the tire specs: BFG TA KDW2's
245/35/19 - 285/35/19
According to Evolution Autosports in VA I will rub.
I am currently on stock ride height, HOWEVER i plan to use OEM 350z springs to lower about .5''.....HEEELP!!!
Now here's my dilemma...I already have tires basically brand new (2-3k miles)...IN case I WILL rub...what offset/size will I need to avoid this problem?? I CANNOT do fender rolling as im scared it'll mess up the paint etc etc etc not to mention I dont know of any shops around VA that can do a good job at this...
Old Jan 28, 2006 | 03:57 PM
Triji's Avatar
You should be fine with the 245 set up in front.... But why a +30 offset?!?!? wow...
The 285's in the back most likely rub... Go with 275's out back.
Old Jan 28, 2006 | 06:21 PM
pdjafari's Avatar
in regards to the offset, this is what they told me they can get. is the offset no good?? my coupe is NON brembo. what is a good offset to have?? i want a big lip....but if i have to sacrifice lip to get these tires to work i WILL!!
Old Jan 28, 2006 | 06:37 PM
jimmytango00's Avatar
the front is going to be tucked in alot... you should go with +19 up front that would look sweet. and +17 rear but then you'd have to roll your fenders in the rear. not sure about the front though
Old Jan 29, 2006 | 01:42 PM
pdjafari's Avatar
OK last minute change of plans!! This is the setup
Volk SF challenges in diamond black
+28 front
+23 rear
will i rub w/ 245/35/19 bfg ta kdw2s and 285/35/19 bfg ta kdw2s??
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alinero718
Sep 27, 2015 09:35 PM
