Need help choosing rims/tires
Old Jan 31, 2006 | 01:08 PM
cloud's Avatar
I'm planning to get rims when I'm getting my tires changed and I'm pretty interested in the 19" gunmetal Volk CE28N / LE28N.
However, I'm new to buying rims/ tires so I need some help here.
I know that the OEM setup is 8" front 8.5" rear but I have seen many people in the forum run a 9.5" Front 10.5" Rear setup.
Does running the 9.5" Front 10.5" Rear sacrifice acceleration or handling, what about road noise? Will it be hard to find replacement tires for this size?
Would 8.5" front 9.5" Rear be a better choice? or is the OEM size the optimum choice? I don't want trouble some setups (like having to roll fenders)
Also, what tire sizes & offsets would you guys recommend for the suggested setups?
Thanks.
Old Jan 31, 2006 | 01:35 PM
Disco_Monkey's Avatar
I have 9.5"+28mm and 10.5"+23mm. I wanted a PHATTER lip on the rear for an agressive look.
Tires are 245/35 and 275/35
I do not rub and I did not roll my fenders, however my drop is only with Eibach Prokits = 1" drop.
Old Jan 31, 2006 | 04:43 PM
cloud's Avatar
How do I determine the offset? I've seen various setups and they all have different offsets.
Also, is it cheaper to get the rims & tires when my tires are worn out(maybe saving on labor or something)? how much would i save approximately.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Jiggerjuice
Dec 6, 2015 10:29 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
