Do I need any modification if I put 19"x9.5 +12 LE37T on the front?
Old Feb 17, 2006 | 03:41 PM
drtech's Avatar
I have a 2005 coupe(w/o brembo).
Thanks
Old Feb 17, 2006 | 06:26 PM
sen_jen's Avatar
Meatshake Enterprise
^ going for the drift look?
Old Feb 17, 2006 | 08:40 PM
KrazyKorean's Avatar
I had the same wheel with +22 and when i lowered it you could def have +12 on the front. Just run a 245/35/19 and you wll be fine. Hell a 255/35/19 would be fine to..
Now I have Gold GT-C's +27 offset and I have a 15mm spacer, which would basically make it a +12 and its perfect. SO you will be fine. And I am running 245's and I could run 255's, but depends on the tire, cuz some are wider then other eventhough they are the same size.
Th611
Oct 27, 2015 03:48 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
Jadenkid22
Jul 14, 2015 12:33 AM
