offset up front?
Old Mar 3, 2006 | 06:55 PM
G-TWIN's Avatar
offset up front?
i just got some ssw d5r 19x8.5 for the front it has a +30 offset will be fine or will i need a spacer or something?
Old Mar 3, 2006 | 08:01 PM
Chico's Avatar
Do you a sedan or coupe? lowered or not? tire size?
Old Mar 3, 2006 | 08:42 PM
G-TWIN's Avatar
I Have A Coupe W/ Brembos, Tire Is 255/35/19, 1 INCH DROP
Old Mar 4, 2006 | 10:26 AM
G-TWIN's Avatar
bump
Old Mar 4, 2006 | 11:23 AM
avs007's Avatar
bump
It really depends on the rim design, as correct offsets vary rim to rim.
I do know the stock rims are +30mm IIRC.
I'm guessing you'll be ok, based on that but I could be wrong.
Mine are +25 up front.
Old Mar 4, 2006 | 01:42 PM
Chico's Avatar
Generally speaking to clear brembos you should be no more than +23 offset. But sometimes you need to go lower because of the wheel design if it is a 1 piece wheel. If it is a multi piece wheel, they usually have different disks for BBK applications.
Old Mar 4, 2006 | 01:45 PM
jimmytango00's Avatar
not sure if offset has anything to do with clearing a BBK ... i think its more on the design of the wheel. I went with a +19 up front and it looks really aggressive and it'll clear brembo's .
Old Mar 4, 2006 | 03:09 PM
robzone's Avatar
i went with +11 on my Junction Produce Scaras
Old Mar 4, 2006 | 06:47 PM
Triple8Sol's Avatar
You can see pics of that wheel on my cardomain. I have 19x9 +24 in the front and 19x10.5 +30 in the rear. I'm running 5mm spacers in the front and rear, but no pics of that though...
Point is, you should've gotten a lower offset..
Old Mar 5, 2006 | 11:00 PM
Gman2004's Avatar
I thought it was the other way around. For brembo's or bbk's you need a greater offset. I have 2004 G35C with brembo's with Volk GT-7's. My offset is +30 up front and +24 in the back. I have 19 x 9.5 and 19 x 10.5.
Old Mar 5, 2006 | 11:08 PM
Chico's Avatar
His wheel in the front is 8.5" hence the recommended offset of +23. I would personally get a +15 offset on a 8.5" wheel with 245/35 tire.
Old Mar 5, 2006 | 11:19 PM
Gman2004's Avatar
duh! I overlooked that part.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
