20" Work VSXX Offset Help
Old Mar 22, 2006 | 11:55 AM
robzone's Avatar
so how much is the cost going to be for the 20's......im dying to know.......i might sell my JP's
Old Mar 22, 2006 | 01:13 PM
sen_jen's Avatar
Meatshake Enterprise
i can get 20 x 8.5 20 x 11 in standard colors shipped to hawaii for $4k. i guess it has to be cheaper than that.
Old Mar 22, 2006 | 07:45 PM
FI'ed G's Avatar
Originally Posted by GSTG35
Heres what Chris at F1 Motorsport said:
I checked the fitment of Work VS-XX 20" You have to different choices.
20x9.5 +31 (2.83" lip)
20x10.5 +25 (3.55" lip)
this fitment, no require any modification fenders.
20x9.5 +18 (3.3")
20x11.0 +19 (4.3")
This fitment, require fenders rolls for the rear.
Chris
I guess we'll find out when it gets here. Then again, I dont even know what dish type Im getting. All I know is Jim @ Work corrected my offsets to +18mm Front / +19mm Rear when the order was placed, and told me the rear fenders will need rolling. Im hoping I get the 3.3 front lip and the 4.3 rear lip. Ill cross my fingers!
Man, if you're getting the second option 4.3" Lip is awsome...
Old Mar 22, 2006 | 08:42 PM
GSTG35's Avatar
Yes I confirmed today that I will be getting the 3.3 Front Lip and 4.3 Lip in the rear.
We had to correct the sizes and the offsets. So here is what will fit the G35's with No Brembo's and minor rolling to the rear fender:
Front: 20 x 9.5 +18 (84mm lip = 3.3")
Rear: 20 x 11.0 +19 (110mm lip = 4.3")
Im a little curious to see how the 11.0 rear will look. They said it will work.
Old Mar 22, 2006 | 08:43 PM
GSTG35's Avatar
I got mine at a very good deal. PM me if you want the info.
Old Mar 22, 2006 | 08:50 PM
GSTG35's Avatar
Ok I just hope they are right, I also had the same deal on other vendor but with +29F and +28R he said it will fit then i spoke to Chris and he said it wont clear the calipers. So i ask the same guy to make sure it will clear my calipers so he email Japan Work to make sure... Guess what, Japan said it wont fit... But if you have confidence go for it, but I will just call Chris to make sure it will fit. Plus even with such a good deal from the other vendor, Chris match it.
Other vendor was selling it for 2400 for set and Chris match the price.. plus you can have a choice for a different color on Rivets (Black or Chrome) for free...
Btw, you were right. The original specs I was ordering I was told was supposed to fit....But I got an email from Japan and they said it was going to stick out of the fenders by ALOT. So research did pay off, and I finally got the right ones comming. Thanks for all the help!
Old Mar 23, 2006 | 04:57 PM
GSTG35's Avatar
nvmd
Old Mar 24, 2006 | 02:00 PM
bjdraw's Avatar
What size tires did you guys end up with?
I would love to get 10.5 or 11 wide rims in the back but I don't care for the stretched look in regards to tires.
With a 10.5 could you run a 315/25R20 and still not rub after rolling the fenders?
What about camber kits, if you correct the camber is it going to rub?
Old Mar 24, 2006 | 05:48 PM
GSTG35's Avatar
Im not even sure what tires to run. Any suggestions for both the front and rears?
Front: 20 x 9.5 +18
Rear: 20 x 11.0 +19
The rear may rub, so Im going to roll the fenders as much as possible.
Old Mar 24, 2006 | 08:31 PM
bjdraw's Avatar
Personally i would run the widest tire I could, but I don't like it when the tires are stretched to fit on the rim like it seems alot of people around here like. The factory 19" are even a bit stretched for my taste.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Albanian122
NorthEast
Aug 3, 2015 10:47 AM
