will 19x9.5 +40 offset work?
Old Apr 5, 2006 | 05:58 AM
redlude97's Avatar
I want to put the axis penta 19x9.5 on the front of my g with a 245/35/19 tire. I believe the offset for these are +40, and normally are used for the rear staggered setup. I was wondering if these would fit without hitting suspension pieces. I understand the optimal offset is +30ish, so I may need to run a spacer, but I want to see if it was possible without a spacer if possible. My goal is the run the 19x9.5 in the front, and 20x10 in the rear with a 3" front lip, and a 4 1/4" rear lip. I checked with a offset calculator, and they should extend 9mm further out than the stock 19s, but extend 29mm further into the wheel well.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
reaper76
Aug 5, 2015 10:13 AM
