20inch rims g35 sedan
Old Apr 17, 2006 | 08:50 PM
g35hartford's Avatar
I recently purchased these rims http://cgi.ebay.com/ebaymotors/20-BL...spagenameZWDVW And i tried to order tires that were. 275/35 in the back and 275/40 in the back, they wouldnt ship the tires because they couldnt gurante it would fit. Does anyone know what size tires i can get that will fit without rubbing. I would appreciate it, thanks alot
Old Apr 17, 2006 | 09:01 PM
(>")> G35's Avatar
A 275 in the front is too wide, get a 245. A 275 in the rear is ok. Offset wise, they are wrong, those ofsets are more suited for a coupe...well wait till the experts post and they'll fill you in much better.
Old Apr 17, 2006 | 09:04 PM
i ment to say 245 in the front, thanks for the help though
Old Apr 17, 2006 | 09:58 PM
codeflux's Avatar
you are about 10mm off on the offset - sedan front 8.5" rim offset should be +43; 9.5" rear should be +43 also. the good thing is that you can have a shop machine 10mm off the wheels - but i've never heard of this actually done.
Old Apr 17, 2006 | 10:03 PM
codeflux's Avatar
as far as tire sizes go, you can use the tire size calculator:
http://www.miata.net/garage/tirecalc.html
i don't remember exactly the stock tire size, but i have 245/35-19 front and 275/30-19 rear, which match the stock tire diameter perfectly.
for the front you can get 235/30-20, and for rear 275/25-20. but don't take my word on it - do more research.
without re-machining the wheels for larger offset (for the wheel to sit deeper inside the fender), you will rub in a major big big big way on all 4 fenders. i don't think rolling the fenders will help.
Old Apr 17, 2006 | 10:11 PM
would spacers make it work or is that making the offset go in the wrong direction? thanks for the help though im prob just gonna cancel the order since this doesnt seem like its gonna work out for me
Old Apr 17, 2006 | 10:14 PM
GEE35FX's Avatar
spacers will push the wheel out further. You want to go the other way .
(>")> G35's Avatar
Your offset is pushing the rims out too far, so adding spacers are going to push the rims out more. Remember when you add spacers you subtract from the offset...
Old Apr 17, 2006 | 10:19 PM
about how much would it cost to machine them down?
Old Apr 17, 2006 | 10:36 PM
Chico's Avatar
Front 20x8.5 +38, 245/35/20
Rear 20x9.5 +45, 275/30/20
That is what I have and that is what I recommend. The rear offset you have will hit the rear fender for sure. You have to roll your fenders to avoid this, and you SHOULD NOT get 275/35/20 as they are too tall. Get the tires I mentioned above and roll your fenders in the rear and you're good to go.
Old Apr 17, 2006 | 10:38 PM
Chico's Avatar
No shop will machine 10mm off the mounting pad. It will compromise the integrity of the wheel. You can probably get away with 5mm and that is cutting it close and something I wouldn't personally do.
Old Apr 17, 2006 | 10:55 PM
codeflux's Avatar
listen to Chico - he knows his rims.
scratch what i said about sizes - go with what Chico recommended in his post. posts. right.
Old Apr 18, 2006 | 05:52 AM
skeleton_cru's Avatar
Sedan
Why even bother? Just get the correct offsets.
Old Apr 18, 2006 | 11:41 PM
well i really like the rims and the price is great, every place i look it seems i cant find what im looking for, for under like 4gs. would rolling my fenders be an option or no? im not gonna bother even trying to machine them I was just wondering if rolling the fenders would work and also how do people roll the front fenders with the ligh directrly on the curve?
Old Apr 19, 2006 | 12:53 AM
Sedan
With that offset and wheel size in the rear, I don't even think rolling the fenders will help. Some guys are running 8.5/+35 in the rear and have slight rubbing issues. A 9.5 wheel will be much worse.
Be patient, don't rush into a wheel purchase without doing your homework. Getting the wrong set-up will just lead to headaches down the road.
