20" maya rt5 owners please chime in
Old May 4, 2006 | 05:41 PM
04Gwhiz's Avatar
how much higher did the car raise from stock height if at all?
i have a 04 with 18" stock
upgrade to 20x9 with 245/35/20 and 20x10.5 with 275/30/20)
some posts in the forums say .5".....just wanted confirm
thanks in advance
Old May 6, 2006 | 11:38 PM
ssk0771's Avatar
ZZ Boy
You have coupe or sedan.
If you have coupe, you should go with 275-35-20 for the rear so you will have stagger setup. If you go with 275-30-20 in the are, your front tires will be higher in diameter by 0.3 inches.
The older G35 Coupes(2003-2005) come with stagger setup. I don't know about 06's
Old May 7, 2006 | 04:16 PM
04Gwhiz's Avatar
thanks...its for a coupe..what ride height difference is there if any?
Old May 7, 2006 | 05:01 PM
ssk0771's Avatar
ZZ Boy
The over all diameter of the tires will be bigger by about an inch. Maybe little less.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
TNRocker
Sep 21, 2015 08:36 AM
DRG35R
Sep 16, 2015 05:33 AM
