wheel spacers
Old May 8, 2006 | 12:26 PM
finallystylin's Avatar
wheel spacers
Have 20mm spacers all around but getting some rubbing on back. Can you run 10mm or less on back w/o affecting the ride? My other option is fender roll but may be hard to find expert around here (memphis).
Old May 8, 2006 | 07:08 PM
help
C'mon, help a brother out!
Old May 8, 2006 | 11:33 PM
redlude97's Avatar
You need to be more specific about what wheels you are running the spacers with so someone can give you better info. We would also need to know what you are dropped on and the offset of your wheels to determine if you can run a 10mm spacer safely. General rule is the total offset in the front should be higher than the rear because the rear usually has a wider wheel on it, so you can get even spacing
Old May 9, 2006 | 11:58 AM
wheel size
18" Verde Chaos +38 offset
wheel size 245/40
I'm really only worried about the car riding funny. I dont think it will be noticeable to the eye with only a small difference. Thanks
Old May 9, 2006 | 02:25 PM
drunkin master's Avatar
I have spacers in the front and i get some vibration on the highway. Its not that bad but deff. can feel the vib.
I don't know about the rear though. I have 5mm spacer not sure about the 20mm in the rear. might rub on the offset. If is does just have the fender cut or rolled.
Old May 9, 2006 | 04:10 PM
Thanks. I can def feel a small vibration with 20mm all around. I'm gonna try no spacers on back and see if it is noticeable. If neccessary I'll just put 5mm on back.
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
