Would these rims fit?
Old Sep 16, 2003 | 08:03 PM
B1ackmarket's Avatar
I currently have a set of 18x8.5 wheels with 35 offset. I also have a set of 245/40/18 tires on the wheels. Will they fit a g35 coupe? If changing the tires will make them fit better, what tires do you recommend?
Old Sep 17, 2003 | 01:28 PM
wreck's Avatar
Running for his life!!
Re: Would these rims fit?
I'm not an expert when it comes to offset, but that setup will look off. Put them on, and to see how it looks.
G35C 6MT / AMG E55
Old Sep 17, 2003 | 02:06 PM
juicedcoupe's Avatar
It depends on if you have the Brembo brakes. The offset is wrong for the front if you have Brembos.
2003 G35 Coupe 6MT
ZEX wet kit jetted for 140 whp
ZEX remote opener
ZEX bottle heater
350 Z intake tube
Amsoil panel filter
Grounding kit
BFG Drag Radials 265/40/18
12.85 @ 108.5
Old Sep 17, 2003 | 06:37 PM
If no brembos, will they fit? Also, what tire sizes would be optimal?
Old Sep 17, 2003 | 07:05 PM
Nismoboy's Avatar
they should fit with that width and offset as long as they're not going on a 6mt w/ brembos...and if your puting on the 245/40/18 for the front thats fine, thats almost the exact same diameter as stock but the rears should be 245/45/18 or 275/40/18 go to www.onlinetires.com they have a good selection good luck
John H.
2003 Infiniti G35 Coupe 5AT-Ivory Pearl-Premium Pkg-Performance Pkg.
Old Sep 18, 2003 | 11:15 AM
DiscountTireCo's Avatar
Your good on the size, and the offset. However...not staggering the tire size front to rear will cause problems with both your VDC...(vehicle dynamic control) and your ABS systems. Typically...I recommend a 245-40-18 & 275-40-18 rear. The 275 is technically too big for an 8.5" rim..but it is possible and safe. The tire will bulge slightly in the rear
Thank you,
Discount Tire Direct
(888)459-4080 mention G35driver
Freeman186
Sep 6, 2023 10:07 AM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
