1/16 in wheel spacer... okay without longer bolts?
Would it be okay to use a 1/16 in. (1.58 mm) wheel spacer without swapping out the hub bolts for longer ones? This seems to be a very small amount and seems that longer hub bolts wouldn't be necessary. Anyone want to chime in otherwise if there would be negative effects of doing this? Thanks.
Yeah, I knew I was going to lose a hair of thread engagement on the lug nuts but figured such a small amount would still be okay. Thanks for the replies. BTW I would only use the spacers for the street. I have the proper offset wheels for the track and won't be using the spacers.
kinetek
Aug 3, 2015 04:25 PM
