Help, just put new tires on!
Old May 17, 2006 | 02:00 AM
holyfrickster's Avatar
hey guys, my stock setup was 225's in the front, and 245's in the rear. The tires were michelin pro pilots. The 225's in the front were done so what i did was change the 245's onto the front rims, and put them in the front and put some new Nitto 555 285/35/18's in the back, no problem whatsoever putting them on, clearance and everything is perfect...As i left my shop i realized that my car would turn waaaaaay better on the streets...But on the freeway at higher speeds...it feels pretty squirly, like when i turn a little bit it jerks the car. I don't know if it is that i have toooo good of traction, or whats going on...The nittos in the back grab great...Just need some opinion from anyone with a similar experience.
Old May 17, 2006 | 08:11 AM
g35rcr's Avatar
let the tires break in...they have to compounds that wear off after a couple hundred miles then the tires grip even better
Old May 17, 2006 | 11:57 AM
Espresso's Avatar
What rims do you have? They can't be stock since you have 18" staggered tires. If they are stock, how did you even manage to fit those size tires on the stock wheels? Since you went much wider on the new tires, check your camber and have an alignment done.
Old May 17, 2006 | 07:33 PM
Yes they are the stock infiniti rims...The tires went on perfectly and no rubbing issues at all. Went on great, and ride great, but i guess that is waht i'll have to do
jsimonk
Dec 22, 2023 03:49 PM
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
mushu
Jul 15, 2015 03:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
